Thread: Rack and Pinion Seal Leaking
11-30-2007, 01:16 PM #1
Ok well i have a leaking rack n pinion...its the top seal where the steering column goes into it and ive done a search and a few people have had this problem and bought just seal a kit. My question is where can i get either all three seals or just that one? Because through GM there is no rack n pinion seal kit...just a bearing kit. Where did you guys get them? thanks
11-30-2007, 04:14 PM #2Member
- May 2007
- houston
black- 2001 z28
go to a local parts store, dealers dont like you rebuilding parts they can bend you over for.
12-06-2007, 01:06 PM #3
sorry this took so long...i already have checked all local parts stores and i know people on this forum have had this problem and bought just a seal kit but where??
12-06-2007, 01:40 PM #4Cookie Monster
- Apr 2007
- Watertown, New York
Navy Blue Metallic- 2002 Z28
If you are feeling lazy, or want to give this a try first, buy some LUCAS power steering fluid treatment. We have used it a few times at the shop and it stops leaks. The bottle gives you a money back guarentee that it will work, might just give a try for the 4 bucks it is.
Pinion Seal
By silverWS6 in forum DrivetrainReplies: 15Last Post: 08-03-2011, 04:56 PM -
Pinion Seal
By silverWS6 in forum DrivetrainReplies: 5Last Post: 04-23-2011, 07:46 PM -
pinion seal leaking
By tdc_v8 in forum Manual TransmissionReplies: 5Last Post: 02-21-2009, 05:42 PM -
Rack and pinion leak... seal kit or replace?
By JehalinTA in forum General HelpReplies: 5Last Post: 02-09-2009, 05:04 PM -
leaking diff seal
By ramairWS6 in forum DrivetrainReplies: 3Last Post: 08-06-2007, 03:28 PM
