Results 1 to 16 of 16
Thread: Pinion Seal
07-25-2011, 08:41 PM #1
Pinion Seal
Yes, again
so I replaced the pinion seal on my 2002 and it only turned out to leak worse than the previous one so upon some web searching I found that 02's have a different seal than the rest of the cars and if replaced with another seal then it'll only leak like a mofo, the way it has been leaking.... Anybody have a clue where I can get the 02 pinion seal? Dealership? If I could get a part number I would forever be thankful!!
07-25-2011, 09:06 PM #2
01-02 Fbody's use the larger pinion seal, which is part number 12471523
I also think you need to remove a sleeve for it to fit correctly if you have the smaller pinion seal.
Either way should work.
07-26-2011, 09:17 PM #3
07-27-2011, 05:12 AM #4
I would verify that part number if you can. I found that information on the other site.
07-27-2011, 09:26 PM #5
Yeah I googled it and came up with some results right away, looks like I'm gonna have to do the pinion seal and yoke seal to stop the leaking. Got the part numbers to those as well now, thanks again!
Edit: Looks like all I come up with is a "yoke kit" ($70ish) can't I just get the seal or is that what the "kit" actually is?
07-28-2011, 04:41 AM #6
07-28-2011, 09:55 PM #7
07-29-2011, 05:57 AM #8
i keep reading that these 10 bolts tend to bust the pinion seal alot... mine needs to be replaced but it a very small leak. is just aggravating to see the bottom of the car all greased up...
07-29-2011, 05:16 PM #9
07-30-2011, 06:44 AM #10
I have the same problem. Always had the greased up under carraige for a small pinion leak. I changed gears and it's the same deal with the new seal. I am going to try a new seal soon, but not expecting any improvement. I get about a drop or two on the driveway after driving as well, super annoying. Maybe someday I'll have the cash for a completely new rear.
07-31-2011, 04:04 PM #11GM World Class Tech.
- Jan 2008
- South Carolina
Black, Black- 2000 Vette, 2006 MC SS
Hate to break it to you man, but usually you only get one chance to replace a pinion seal after the crush sleeve on the pinion has been crushed. Usually by the second attempt the crush sleeve is shot.
This requires the pinion to be pulled back out and a new crush sleeve installed prior to the new pinion seal being installed.
You might get away with it...but the preload will probably end up on the high side, and pinion bearing failure will result.
07-31-2011, 05:09 PM #12
07-31-2011, 09:41 PM #13
Well it looks like I tried to bite a bullet that's too big for me...
Last time I replaced it, I just pulled the driveshaft out (only on the rearend side), took out the yoke then pulled out the old seal, put the new seal in, tightened the yoke bolt(?) again, put the driveshaft back and called it a day
08-03-2011, 06:30 AM #14
hmm, so basically it's best to just leave it be? so, if one is to stop the chronic leaks, one has to do an differential overhaul and re-setup to properly get a new seal and crush sleave on? seems mine has always leaked, and continues even after a diff rebuild a few years ago...
i guess the question is - does anyone have one that doesn't leak?
08-03-2011, 12:51 PM #15
Mine started leaking at 12K miles on a garage queen. That was right about the time I got my 9". I got lucky and was able to sell it for $425
08-03-2011, 04:56 PM #16GM World Class Tech.
- Jan 2008
- South Carolina
At the chevy dealership we have a hunch that the reason pinion seals leak on these f-body's is because of the torque arm design.
This is only a hunch and I don't have actual proof. I think that the bolts for the torque arm that run through the snout of the rear differential housing may cause the housing to distort at the pinion seal area and become slightly out of round. You would most likely not see it with your naked eye and of course the new seal will take the shape of the housing when driven in. This will cause the new seal to start leaking after no time at all.
When I had my 2002 WS6 I just lived with the seepage. If its leaking badly then you may want to take a close look, or even measurements, of the pinion seal
bore.
Like I said...I don't know this to be fact. Just some food for thought.
Pinion seal.
By goof4080 in forum DrivetrainReplies: 3Last Post: 06-21-2012, 06:09 PM -
Pinion Seal
By silverWS6 in forum DrivetrainReplies: 5Last Post: 04-23-2011, 07:46 PM -
Pinion Seal
By Kamesense in forum DrivetrainReplies: 3Last Post: 05-14-2008, 07:27 AM -
pinion seal
By AF1Strider in forum DrivetrainReplies: 5Last Post: 04-08-2007, 01:23 PM -
Pinion seal
By jimmy77611 in forum DrivetrainReplies: 25Last Post: 03-10-2007, 05:51 PM
the problem started when I did my gears, the guy apparently put the wrong seal on so that would leak a little so then I tried replacing it and then it just kept leaking but it was more this time.
