Thread: Pinion Seal
04-23-2011, 04:00 PM #1
Pinion Seal
Whose done it? I just did mine and when I put everything back together I found a washer that possibly goes between the yoke and the nut that holds the yoke. I don't remember taking that washer off but maybe it stayed stuck to the yoke and when I put the yoke down then it came off. I put everything back together and found that washer laying there, now I'm not sure if it belonged to my car though cause I did the work at school and there is always pieces like that laying around... I kept the washer anyways though just in case. So I need someone that has done this before to see if you guys remember a washer being between the yoke and the nut that holds the yoke...
04-23-2011, 04:37 PM #2
I could go check my manual, but as far as I know... there should be a washer. What was your procedure for tightening the pinion nut?
04-23-2011, 05:09 PM #3
I think there is one too but ahhh what a pain to take it apart again... I used a impact to tighten it
ops: you think I could've damaged the bearing?
Moral of the story, don't let other people help you
04-23-2011, 05:16 PM #4Senior Member
- Apr 2008
- Madison, WI
There is definitely a washer between the nut and yoke. Tightening with an impact is fine if done correctly.
04-23-2011, 05:22 PM #5
Well good thing I saved the washer... I guess ill have to take it apart again. Thanks guys!
04-23-2011, 07:46 PM #6
Pinion seal.
By goof4080 in forum DrivetrainReplies: 3Last Post: 06-21-2012, 06:09 PM -
Pinion Seal
By silverWS6 in forum DrivetrainReplies: 15Last Post: 08-03-2011, 04:56 PM -
Pinion Seal
By Kamesense in forum DrivetrainReplies: 3Last Post: 05-14-2008, 07:27 AM -
pinion seal
By AF1Strider in forum DrivetrainReplies: 5Last Post: 04-08-2007, 01:23 PM -
Pinion seal
By jimmy77611 in forum DrivetrainReplies: 25Last Post: 03-10-2007, 05:51 PM
