Thread: Pinion Seal
05-03-2008, 02:52 PM #1
Pinion Seal
I put my car up to get some new rear meats this weekend and noticed that my rear pinion seal is startin to leak a little. It seems to be minor at the moment but im hoping it doesnt get worse fast.
Anyone recommend any particular course of action? Should i just change the seal? Car makes 325whp and 342wheeltq
05-04-2008, 02:19 PM #2Senior Member
- Apr 2008
- Madison, WI
I'd say if there is a drip hanging off then fix it. If its seaping then keep your eye on it. I just did mine 5 days ago and rechecked it today to find the outside of the housing bone dry and not leaking a bit. I used a GM/ACDelco seal from the dealership.
05-05-2008, 04:15 PM #3
Its not dripping which is good it does just seem like light seepage. Im gonna try to hold off on changing it then and keep an eye on it.
05-14-2008, 07:27 AM #4
These cars are known to leak a bit from the pinion seal - that's pretty much normal. I wouldn't worry about it, unless you see actual dripping or a puddle on the ground.
Pinion seal.
By goof4080 in forum DrivetrainReplies: 3Last Post: 06-21-2012, 06:09 PM -
Pinion Seal
By silverWS6 in forum DrivetrainReplies: 15Last Post: 08-03-2011, 04:56 PM -
Pinion Seal
By silverWS6 in forum DrivetrainReplies: 5Last Post: 04-23-2011, 07:46 PM -
pinion seal
By AF1Strider in forum DrivetrainReplies: 5Last Post: 04-08-2007, 01:23 PM -
Pinion seal
By jimmy77611 in forum DrivetrainReplies: 25Last Post: 03-10-2007, 05:51 PM
