02-07-2009, 09:59 AM #1Member
- Jan 2006
- houston
Navy Blue- ls1 trans am
Rack and pinion leak... seal kit or replace?
Ok I noticed that my power steering has been leaking from the rack and pinion. It has only been noticable for the last couple of weeks. There is power steering fluid on the bottom area. There is no difference or noise when I drive and the leak is not too bad. Will a seal kit, I assume a gasket or O-Ring of some sort, fix the problem. Or is this something that I would be better off replacing the whole rack and pinion. The R&P sells for roughly 200 and the seal kit is only 21. Thanks guys
02-07-2009, 02:51 PM #2
That would just depend on how much extra money you have. I have heard horror stories about air in the steering, may be wise to get it done.
02-07-2009, 05:57 PM #3Member
- Jan 2006
- houston
Well I have put money into the car recently. I would like to do the repair myself because it doesnt seem to be too hard. I guess my question is if there is a way to check if it is just a seal leaking. Is this something common in the LS1 TAs. I just dont want to take everything apart replace the seal then the problem be something else and I would have to do everything all over again. So I would rather put in a new Rack and Pinion if the seal is not a good possibility. Thanks
02-07-2009, 07:37 PM #4Awaiting Activation
- philadelphia
red- 2000transam
Mine started a very slow leak on the driverside at the inner tierod boot with around 20,000 miles .It never gave me a problem but i found a used oem one on ebay and replace it at 32,000 and works great ,so i would have to say it's pretty much a common problem .If you decide to do it yourself, there one bolt on the driverside that will not come out without lifting the motor up or cutting the head off of the bolt and replace one upside down thats what i did.
02-08-2009, 04:50 AM #5
02-09-2009, 05:04 PM #6Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Mine leaked from the pump cap...I put some weak silicone on the threads and put the cap back on...no more leaking
Pinion Seal
By slade8200 in forum DrivetrainReplies: 0Last Post: 09-22-2014, 05:53 PM -
Pinion Seal Leak
By jcws6 in forum DrivetrainReplies: 5Last Post: 09-11-2008, 12:43 PM -
Rack and Pinion Seal Leaking
By cdorch in forum General HelpReplies: 3Last Post: 12-06-2007, 01:40 PM -
New Rack and pinion needed, what else to replace?
By 98LS1 Mike in forum Suspension and HandlingReplies: 1Last Post: 07-20-2007, 07:15 PM -
Pinion seal leak
By 98ls1blackbird in forum DrivetrainReplies: 0Last Post: 06-10-2007, 04:15 PM
