    Member Z28LS1's Avatar
    New Jersey
    1999 Camaro Z28 M6
    Rear differential fluid change
    Hey guys, I feel I need to change my rear differential fluid. My car has 83xxx miles on it and the rear end cover bolts are really rusted. I'm afraid i'm going to break a bolt when i try to take the cover off.. Has this happened to anyone? Should i be worried or are the bolts strong enough? Thanks.
    2 SS's are better than 1 Jays00ss's Avatar
    Lathrop, Missouri
    NBM / Silver
    00 SS / 71 SS Elcamino
    Quote Originally Posted by Z28LS1 View Post
    Just use some good penetrateing oil and let it soak for a a while. You Can always use an easy out to get the bolt out if you had to. Also a little heat would help if you have issues. You should be ok, just don't use a 3/4" drive breaker bar with a cheater.
    Senior Member
    rochester,ny
    pewter
    2001 z28 lingenfelter 383
    how do u change the fluid? how much does it take? which kind to use? was thinking of installing a stronger rear end " pumpkin" for strength and i have no clue what im getting into but it would seem to be simple
    Remove the 10 bolts from the cover and let the fluid drain out, and it will stink badly. It takes about 2.5-3 quarts to refill it. Get a new gasket or a gasket maker at a local parts store and you are good to go.
    Painted manta stripe
    hose those bolts down with pb blaster and let them sit for a little while and you'll be fine.
    Senior Member
    rochester,ny
    pewter
    how do u refill it? if taking the bolts off lets the fluid out..how do u put it back in? lol..... i appologize if this sounds dumb......i havnt taken a close look at it yet
    Arizona
    The fill plug is in the passenger side of the carrier near the pinion. Remove with 3/8 drive extension. Fill housing to the bottom of the fill hole, reinstall plug. After running the car, and a complete cool down, it's a good idea to recheck the level,,,sometimes they need a topping off.
    Senior Member
    rochester,ny
    pewter
    ty very much...recommmendation of rear diff fluid to use?
    Lathrop, Missouri
    NBM / Silver
    Quote Originally Posted by tonyjnjz View Post
    Royal purple (75W-90) then you won't (Will not) need the Posi additive.
  1. Differential Fluid change
    By LIGHTNINGMCQUEEN in forum Drivetrain
    Last Post: 04-04-2011, 12:11 AM
  2. Did a rear end fluid change...
    By RPO_WU8 in forum Drivetrain
    Last Post: 09-26-2009, 12:06 PM
  3. Question: Rear Differential Oil Change Question
    By M-ManLA in forum Drivetrain
    Last Post: 05-07-2009, 03:23 AM
  4. Rear end fluid change
    By whiteLS1TA in forum Drivetrain
    Last Post: 01-18-2008, 02:14 PM
  5. differential fluid change
    By thirdbird in forum Drivetrain
    Last Post: 04-12-2006, 02:55 PM
