05-06-2009, 12:07 AM #1Markeyse Jamar Mundy
- Jan 2009
- Sylmar, California, United Sta
Gray- 2000 Camaro GT Street V6
Rear Differential Oil Change Question
Ok I will attempt to change my rear diff oil this weekend. Here is a list I had compiled. Let me know if I am missing anything.
75w-90 Synthetic Gear Lubricant
New Camaro 10 bolt Gasket
Brake Cleaner
Now I know someone says to use brake cleaner, but what do I have to clean? Also any suggestions will be appreciated.
05-06-2009, 11:10 AM #2Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
You need brake cleaner to clean the diff cover.
05-06-2009, 12:31 PM #3Member
- Nov 2008
- harrisburg pa.
black- 02 vette vert
05-06-2009, 12:49 PM #4
Generally the synthetic comes w/ the additive but you should check anyway. I have heard of people gaskets leaking, you might look into the "right stuff" it's a gasket maker that cures fairly quick.
05-06-2009, 11:23 PM #5Markeyse Jamar Mundy
- Jan 2009
Ok good info.
05-07-2009, 03:23 AM #6
Some RTV Gasket maker, and i would reccomend a good putty knife or a small wire wheel that attaches to a drill.
Makes the old gasket removal alot easier..
Differential Fluid change
By LIGHTNINGMCQUEEN in forum DrivetrainReplies: 31Last Post: 04-04-2011, 12:11 AM -
Rear differential fluid change
By Z28LS1 in forum DrivetrainReplies: 8Last Post: 03-15-2008, 06:42 AM -
WTB Rear Differential
By Xtap in forum Parts Wanted / TradeReplies: 3Last Post: 09-17-2006, 02:13 PM -
By thirdbird in forum DrivetrainReplies: 3Last Post: 04-12-2006, 02:55 PM -
Rear Differential ?
By CAMZARO in forum DrivetrainReplies: 3Last Post: 01-07-2006, 02:14 PM
