Thread: differential fluid change
04-01-2006, 05:24 PM #1Junior Member
- Mar 2006
- Tennessee
black- 1999 Pontiac Trans Am
I am going to change the differential fluid in my 99 TA in the next couple of weeks. Is there anything I need to inspect or look for while the cover is off of the differential?
At 77,000 miles I have some gear whine and noise, but think this is probably normal. These cars dont have very much sound deadening in the back.
Do the differential bearings fail at a higher than normal rate in F body cars? If so, how do I know if I have a bearing failing.
Thanks
04-02-2006, 11:26 AM #2Member
- Maryland; USA
- See signature.
check for any chipped teeth thats one of the biggies to look for. also look for abnormal amounts of metal shavings thats all i can think of.
Pontiac Firebird's: 91 Formula 350, 01 Trans Am WS6, Suzuki's: 09 SX4 Crossover, GSX-R's: 06 600 & 07 1K.
F-Quick Garage & Car Domain
04-10-2006, 05:26 PM #3
should switch to a synt. lube
04-12-2006, 02:55 PM #4
some syth wont work with the posi unit, if you're going to do that do some research first. You don't want to run into trouble with it locking. Amsoil is one of these as I have found out from person experience. It's really only necissary if you are doing autox or racing at high speeds for prolonged periods of time where you need insurance of those friction modifiers back there to keep things cool
Differential Fluid change
By LIGHTNINGMCQUEEN in forum DrivetrainReplies: 31Last Post: 04-04-2011, 12:11 AM -
Help: Trans and differential fluid
By 98maro in forum General HelpReplies: 20Last Post: 03-29-2010, 05:50 PM -
Question: Differential fluid
By mdcrabbie in forum DrivetrainReplies: 2Last Post: 02-27-2009, 06:46 PM -
Rear differential fluid change
By Z28LS1 in forum DrivetrainReplies: 8Last Post: 03-15-2008, 06:42 AM -
Differential Fluid?
By shlby123 in forum General HelpReplies: 12Last Post: 03-13-2007, 11:19 PM
