Results 1 to 13 of 13
    Feb 2006
    Differential Fluid?
    How do you add it to your car?
    Dawson, IL
    2000 Trans Am
    Fill plug is on the passenger side of the car directly in front of the rear axles at the pumpkin - use a 3/8 drive extension to screw it out and fill till it flows back out
    Feb 2006
    pretty cool. Thank you!
    Senior Member
    Jacksonville, FL
    Also make sure the car is level when filling.
    ORNGP33L 1BADDLS1's Avatar
    Long Island, NY
    Hugger Orange
    1999 Camaro Z-28
    Verify that the axle lubricant level is within the following range:
    No higher than the bottom of the plug opening
    No lower than 15 mm (9/16 inch) below the plug opening
    If necessary, add to or replace the axle lubricant. Use synthetic 75W-90 gear lubricant (GM P/N 12378261), meeting GM specification 9986115, or equivalent.
    If the vehicle has a limited slip differential, add 118 ml (4 fl oz) of limited slip differential additive (GM P/N 1052358), or equivalent
    Feb 2006
    Im assuming the diff. fluid is the lubricant right?
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by shlby123 View Post
    Yes, its the lubricant.
    Jun 2006
    irving
    candy red
    98 Camaro Z28
    What weight to use and will royal purple be the differential fluid?? I have never changed it on my 81k Camaro and was wondering if it would be worth to change it.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by CandyRedZ28 View Post
    Yes I would..... Royal Purple's is called Max-Gear. It's not # like plain jain fluid. You will gain gas milage do to loss of friction. And even better yet there is NO need to add any friction modifier cause it already has it.
    Heres a link if you want proof of the truth.....
    http://www.royalpurple.com/prodsa/mgeara.html
    I'm gonna have to hunt it up again to be completely positive but I think rears with clutch type posi's aren't recommended synthetics. I think you can run synthetic in the cone types but not the clutch types. I know my strange rear is not recommended to run synthetics.
    Jun 2006
    irving
    candy red
    98 Camaro Z28
    So what do i got, mine is a 98
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Stock GM clutch type are ok with sythetics. They call for a GL-5 type oil. Or at least everyone I've ever dealt with has.
    This is from R.P.
    "Max-Gear is recommended for use in truck, motor home / RV, and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid."
    "All viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary."
    Michigan
    2002 Camaro ss
    Thumbs up
    I would change it ASAP.
    It is great insurance, and the rear ends in these cars are weak to begin with.
    I'm just about to buy a rear end cover that has a drain plug in it so fluid changes can be easy. SLP offers one and I believe a company that sells Trans-am parts has a good one as well. (don't know the name of this co.)
    Good peace of mind to have new fuild in her .
    All the best to you.
    jess .........
  1. Differential Fluid change
    By LIGHTNINGMCQUEEN in forum Drivetrain
    Last Post: 04-04-2011, 12:11 AM
  2. Help: Trans and differential fluid
    By 98maro in forum General Help
    Last Post: 03-29-2010, 05:50 PM
  3. Question: Differential fluid
    By mdcrabbie in forum Drivetrain
    Last Post: 02-27-2009, 06:46 PM
  4. Rear differential fluid change
    By Z28LS1 in forum Drivetrain
    Last Post: 03-15-2008, 06:42 AM
  5. differential fluid change
    By thirdbird in forum Drivetrain
    Last Post: 04-12-2006, 02:55 PM
