Thread: WTB Rear Differential
09-10-2006, 03:11 PM #1Junior Member
- Sep 2006
- Michigan
- iTrader
- 0
Red- 2004 Gto
My trans am is currently sitting busted in my garage to the effect of 4 teeth off the pinion gear "whoops". I need a rear differential that will fit in it. I don't really care about the gear ratios, as long as it's posi and will bolt on I just need to throw one under it. The car is sold as soon as I get this put in so if anyone has anything that can help me out let me know.
09-10-2006, 07:26 PM #2Got Juice?
- May 2006
- Knoxville, TN
- iTrader
- 5 (88%)
Silver- 2002 Trans Am WS6
Rear end
I have a 10 bolt out of my 2002 ws6 for sale. It has 35000 miles on it and has the traction control rings as well. i'm asking 300.00 obo. thanks i hope i can help you out.
09-11-2006, 09:35 PM #3adudeGuest
Have one out of my 01 SS(3 ch ABS) for $100 & shipping if you can use 2 of your old parts. PM your phone # and good time to call if you are interested. LMK Thanks, Dan
of my 2001 SS. 3 channel ABS = no traction control. Ready to go with your good driver's side axle shaft. My housing is great, but my driver's side axle's outer wheel flange is bent) If you send me your old ABS exciter ring and pick-up so I can use it in the 9 inch I'm building, ors
ell it for $100 plus shipping. LMK E-mail is fastest.
Thanks, Dan
09-17-2006, 02:13 PM #4
i have a built 10 bolt entire assembly, less then 10 miles, asking $1,000
cheaper then paying to rebuild, and is built with a stronger auburn pro carrier, richmond pro set gears, and c clip eliminators.
Rear Differential
By VinnieV02TA in forum DrivetrainReplies: 19Last Post: 10-15-2010, 09:41 AM -
Question: Rear differential...
By 99Bandit in forum Automatic TransmissionReplies: 0Last Post: 06-15-2008, 09:08 PM -
which TYPE of rear differential?
By Zapper2003 in forum General HelpReplies: 0Last Post: 11-11-2007, 08:09 AM -
Rear differential ticking
By eddielb in forum Firebird / WS6Replies: 4Last Post: 05-16-2006, 09:55 PM -
Rear Differential ?
By CAMZARO in forum DrivetrainReplies: 3Last Post: 01-07-2006, 02:14 PM
