Thread: Did a rear end fluid change...
09-23-2009, 10:33 PM #1Junior Member
- Jun 2006
- Pocatello, ID
Black- 2000 SS Camaro
Did a rear end fluid change on my 2000 SS which now has 58K on it. I hadn't done one in about 35K miles and the fluid looked just fine. I put in what I always put in mobile 1 75/90. used a new gasket yadda yadda yadda but my real question is GM additive 89021958 is what was sold to me at the dealership when I asked for limited slip additive. This crap was like $19! and it looked different then what i used last time which I think was part # 1052358. The guy at the counter said that this was the new part number and it replaced the old one. Anways I dumped it all in (I think 4 ounces) and now I am reading that is a concentrate and you are only supposed to use like 1 ounce or something like that and its for a GTO or something. I have not drove it more than maybe 2 miles and everything sounded ok but whats the story here. Did I screw up and use the wrong stuff? Is the guy from the GM dealership full of crap? I am going to have problems? Doing this kind of work is a PITA cause I live in a apartment and I do not want to change out new fluid but if I need to I will. Talk to me folks.
Thanks,
09-24-2009, 12:17 AM #2Junior Member
- Jan 2007
- Michigan
Black- 2002 Camaro ss
Hey RPO_WU8
I installed a TA girdle on my rear end about a year ago
and went with royal purple syn. I also used the GM additive even though
some would say you don't need it with the syn. I would not worry
about your set-up, it sounds just fine. I don't believe your GM parts man
would steer you wrong. By the way I did my cover and fluid change
in my backyard on a nice spring day with ramps and jack stands.
Where did you do your job ? I like working on my car.
All the best.
jess
__________________________________________________ ________
2002 ss - Black - A4 - 323 - SLP loudmouth 11 - SLP lid - SLP # 5846
09-24-2009, 06:31 AM #3
I use mobil 1 gear oil with 4 ounces of Kendall additive with no problems. The additive isn't necessarily need with the torsen differential.
http://www.torsen.com/general/genera...difier%20added
09-24-2009, 07:43 AM #4Junior Member
- Jun 2006
- Pocatello, ID
Been using the additive..
But the one I put in #89021958 did not look like the usual whale sperm LOL that I had been getting through GM. This one looked like some kind of medium green dye. I used to run without the additive (older whale sperm lol) but it was a bit noisy and using the old additive it was much quieter but at $19 I wonder if what I put in was so radically different that I may have put in the wrong stuff. Plus I did a search on it and it mentions it being for a new GTO and to only add 1 ounce instead of the entire 4 ounce that came in the bottle.
09-24-2009, 06:11 PM #5
09-26-2009, 04:49 AM #6Senior Member
- Apr 2008
- Madison, WI
This is the stuff I usually use and its ok to put in extra.
09-26-2009, 12:06 PM #7
That is the stuff I used as well, but I don't have a Torsen.
09 Vulcan 900 custom.
2007 Subaru Legacy 2.5i
1998 Z/28 Hardtop A4 | Y2K wheels | SLP Lid | Magnaflow catback |cutout | Hotchkis LCA'S/PHB | BMR TA and D/S Loop| Tuned by Frost....300rwhp/308rwtq
97 Cobra- bolt ons | full exhaust| 4.30's| suspension | SCT tune- sold!
rear diff. fluid change
By z28_81 in forum DrivetrainReplies: 3Last Post: 06-06-2009, 10:37 AM -
doing a rear axle fluid change correctly
By 02transamce in forum DrivetrainReplies: 2Last Post: 02-04-2009, 09:59 PM -
with rear gear fluid change.....
By clg82 in forum DrivetrainReplies: 19Last Post: 07-23-2008, 12:26 PM -
Rear differential fluid change
By Z28LS1 in forum DrivetrainReplies: 8Last Post: 03-15-2008, 06:42 AM -
Rear end fluid change
By whiteLS1TA in forum DrivetrainReplies: 15Last Post: 01-18-2008, 02:14 PM
