Results 1 to 3 of 3
02-01-2009, 07:54 PM #1
doing a rear axle fluid change correctly
i want to change my rear axle fluid,02 trans am a4.what weight fluid,how much fluid,and what is the gm part number for the rear axle additive?i just want to get the right stuff,so i ask the experts!!
02-04-2009, 09:01 PM #2
It’s called ACDelco Limited slip axle Lubricant additive and I have no Idea which one is the part# but the top number is 10-4003 and bottom is 88900330. It is a common part and if you just go to GM and ask for the limited slip additive they will know what you need. Gear oil is 80W. Instead of having to remove the cover you can take it to a quick lube that has a siphon tube to suck out all the old gear oil and take your own fluid and additive for them to put in and then just drive out and do figure 8’s and then check for posi.
02-04-2009, 09:59 PM #3
you can also get the gm additive at pretty much any parts store.
Did a rear end fluid change...
By RPO_WU8 in forum DrivetrainReplies: 6Last Post: 09-26-2009, 12:06 PM -
rear diff. fluid change
By z28_81 in forum DrivetrainReplies: 3Last Post: 06-06-2009, 10:37 AM -
with rear gear fluid change.....
By clg82 in forum DrivetrainReplies: 19Last Post: 07-23-2008, 12:26 PM -
Rear differential fluid change
By Z28LS1 in forum DrivetrainReplies: 8Last Post: 03-15-2008, 06:42 AM -
Rear end fluid change
By whiteLS1TA in forum DrivetrainReplies: 15Last Post: 01-18-2008, 02:14 PM
