Thread: rear diff. fluid change
06-05-2009, 09:49 PM #1Junior Member
- Feb 2006
- houston
pewter- 2001 camaro z28
so i have a 01 z28 4a with 75k on it... ibought the car used with 45k on it back in jan.05. i dont know if the previous owner ever changed the fluid. will it hurt my diff. if i change it now???
also which diff. does my car have ...torsen or aurburn??
is this all i need to change it..
2qts m1 75w90
gasket
high temp sylicone
gm additive.
do i need a torque wrench to tighten the bolts?? and whatsequence should i tighten the bolts to get a proper seal???
06-06-2009, 05:41 AM #2
You should have a torsen diff. Either way you have the right supplies to service both. Tighten the bolt is a criss cross manner as you would a tire. I used a torque wrench and 25 foot pounds. But it's not nessessary.
06-06-2009, 09:51 AM #3Junior Member
- Feb 2006
- houston
06-06-2009, 10:37 AM #4
Did a rear end fluid change...
By RPO_WU8 in forum DrivetrainReplies: 6Last Post: 09-26-2009, 12:06 PM -
doing a rear axle fluid change correctly
By 02transamce in forum DrivetrainReplies: 2Last Post: 02-04-2009, 09:59 PM -
with rear gear fluid change.....
By clg82 in forum DrivetrainReplies: 19Last Post: 07-23-2008, 12:26 PM -
Rear differential fluid change
By Z28LS1 in forum DrivetrainReplies: 8Last Post: 03-15-2008, 06:42 AM -
Rear end fluid change
By whiteLS1TA in forum DrivetrainReplies: 15Last Post: 01-18-2008, 02:14 PM
