Results 1 to 16 of 16
Thread: Rear end fluid change
10-24-2007, 01:00 AM #1
im going to change my rear end fluid tomorrow. i mean i dont need to with my car only having 40,000 miles but i like haveing my baby haveing the best fluids, but i dont really know what fluids to use. i got some redline rear end fluid, is that a good brand?
10-24-2007, 10:40 AM #22 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
10-25-2007, 05:30 AM #3
Lucas FTW!!!!!!!!!!!!
10-28-2007, 09:30 PM #4
lucas made mine whine...:\
10-29-2007, 12:03 PM #5Impounded
- Feb 2007
- Pa
Red- 99 TA
lucas is a terrible choice...amsoil or any good regular brand name.Royal purple is over priced junk too.
10-29-2007, 07:28 PM #6
11-01-2007, 08:55 AM #7
11-01-2007, 09:05 AM #8
11-01-2007, 12:10 PM #9
Mine currently has NAPA in it. So does my buddies, Been fine for 4 years now. Not a prob.
11-03-2007, 07:26 AM #10Senior Member
- May 2007
- Bartlesville, Oklahoma, United
Bright Rally Red- 2000 Camaro SS #5075 M6
royal purple ftw
01-15-2008, 04:50 PM #11Junior Member
- Jan 2008
- Tampa, FL USA
Here's a good study recently published on auto gear lubes
01-16-2008, 06:17 PM #12
I would use any dino 80/90 gear oil. Synthetic isn't necesarry. Neither Moser nor Strange recommend syn for their 12 bolts and I used Redline shockproof syn gear oil in my old 10 bolt once and I started getting one wheel peels at the track.
01-16-2008, 07:08 PM #13
75/90 amsoil is what sarge recommends,took my whine away after a couple of wot runs
01-17-2008, 08:52 AM #14
01-17-2008, 09:32 AM #15
unbolt the 12 bolts around the pumpkin .....inspect the magnet inside the case...clean inside the case with brake cleaner....grab the gasket maker and make GOOD ENOUGH SEAL ON THE CASE WHERE YOUR SURE IT WONT LEAK..bolt it back up....add lube through the back of the pumpkin..there you can just lay your wrench with out any sockets and unbolt
01-18-2008, 02:14 PM #16Junior Member
- Jan 2008
- Tampa, FL USA
About your experience with Synthetic
Limited slips have some special lube requirements. Not all rear end lubes are formulated the same. I did a short article on limited slip diff chatter a couple of months back. May be interesting to you.
Regards...
Did a rear end fluid change...
By RPO_WU8 in forum DrivetrainReplies: 6Last Post: 09-26-2009, 12:06 PM -
rear diff. fluid change
By z28_81 in forum DrivetrainReplies: 3Last Post: 06-06-2009, 10:37 AM -
doing a rear axle fluid change correctly
By 02transamce in forum DrivetrainReplies: 2Last Post: 02-04-2009, 09:59 PM -
with rear gear fluid change.....
By clg82 in forum DrivetrainReplies: 19Last Post: 07-23-2008, 12:26 PM -
Rear differential fluid change
By Z28LS1 in forum DrivetrainReplies: 8Last Post: 03-15-2008, 06:42 AM
