Thread: coolent help plz
07-20-2006, 08:30 PM #1Junior Member
- dover delaware
sport gold matalic- 98 firebird formula
coolent help plz
i have a 98 formula and need to know what kind of coolent i need to use??
07-21-2006, 04:56 AM #2
Dexron. It is the Orange looking kind and not the green kind. A good thing to add might also be some Purple Ice or Water Wetter which helps cool things off a little more.
98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
07-21-2006, 09:19 AM #3
i have the purple ice , you best be is the SLP fan switch, with the fans on low i run a constant 180 degrees
07-21-2006, 12:07 PM #4Senior Member
- Jul 2005
- Jacksonville, FL
50/50 mix Dexcool/water + any additive if you need extra cooling.
07-21-2006, 11:58 PM #5Junior Member
- dover delaware
cool thanks i just found my leak and its my water pump... any one change one?? how long did it take??
07-22-2006, 03:09 AM #6
Not a bad swap if I remember correctly. It's been a couple of years since I swapped mine out. I'm not a good person to ask as far as how long it took. I always take my time and I'm never in a hurry. I'd say it probably took me a couple of hours so I would guess a motivated person could do the swap in an hour or less.
07-23-2006, 10:02 AM #7maroonZGuest
remeber to check to see if the dexcool you have is premixed or not.
Help: coolent smell
By TJKIDD in forum General HelpReplies: 5Last Post: 04-25-2011, 04:56 PM -
oil in my coolent
By jAgZ28 in forum LT1Replies: 1Last Post: 12-09-2010, 09:05 PM -
Low coolent light is on for no reason
By SStatus in forum General HelpReplies: 15Last Post: 07-14-2007, 04:43 AM -
Do all ls1 intakes after 00 come with coolent plugs?
By mach350z in forum External EngineReplies: 3Last Post: 06-08-2006, 09:28 AM -
Where is the Coolent Level Sensor on 98 Z28 ?
By samualt in forum General HelpReplies: 1Last Post: 06-01-2006, 01:58 AM
