Thread: coolent smell
    Junior Member TJKIDD's Avatar
    Mar 2011
    San Antonio,tx
    1999 camaro z28
    coolent smell
    Last night me and my girl were going on a cruise so when we got home i could smell coolent idk why i checked under the car to see if its leaking and not a drop, plus i smelled the exhaust leaking but im pretty sure that doesnt cause the coolent to leak. So i was wondering do yall think i have a tiny leak that i can't see? Its a 99 z28 a4.
    Pittsburgh
    2008 Hummer H3
    Could be your heater core starting to leak..
    The exhaust could have a leak did you delete the cats?
    Sometimes the exhaust takes on a different smell when they are deleted..
    Could be exhaust blowing back into the car through an open window aswell..
    Just my .02
    Mar 2011
    San Antonio,tx
    1999 camaro z28
    I haven't deleted the cats yet im planing to just replace the whole exhaust system. And i think it is the exhaust smell cause i was outside just to rev it and i only smelled it when it was reving.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Once you replace the exhaust, let us know how you make out and keep us posted if you still smell the odor.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Like Steven stated, check the heater core. If this is leaking most likely the carpet on the passenger front side will be wet.
    Check your fluid level - surprised nobody suggested this. Is it low?
    How has your temperature been running? Normal? If not, your water pump could be on its way. A water pump will usually start to weep when it is going out...sometimes you can even hear the bearing in it going bad.
    Lastly, check all your hoses. Make sure a connection did not come loose or that a hose has not deteriorated.
    If all that checks out and you can't see any physical leaks, but you are low on coolant, it is possible that you are leaking coolant through the exhaust. This is usually indicative of a head gasket leak. Coolant is being burned off in the exhaust chamber and exiting through the exhaust. The only way coolant can get into the exhaust chamber is through the head gasket. Check your oil. Does it look normal? Is it milky white? If so, you've found the problem. Also, if you rev the car up and see an abnormal amount of white smoke coming from the exhaust tips, this is another clue.
    If all that checks out OK, you're probably smelling the exhaust fumes without cats...
    Oct 2010
    n/a
    n/a
    Yes one time it came out like a waterfall out of a jeeps "ducts"
  1. oil in my coolent
    By jAgZ28 in forum LT1
    Last Post: 12-09-2010, 09:05 PM
  2. Low coolent light is on for no reason
    By SStatus in forum General Help
    Last Post: 07-14-2007, 04:43 AM
  3. coolent help plz
    By rshooch in forum General Help
    Last Post: 07-23-2006, 10:02 AM
  4. Do all ls1 intakes after 00 come with coolent plugs?
    By mach350z in forum External Engine
    Last Post: 06-08-2006, 09:28 AM
  5. Where is the Coolent Level Sensor on 98 Z28 ?
    By samualt in forum General Help
    Last Post: 06-01-2006, 01:58 AM
