06-06-2006, 09:08 AM #1
- May 2006
- calif
dwd- wdwd
Do all ls1 intakes after 00 come with coolent plugs?
Do all ls1 after 2000, which come from the factory utilize the gm coolent line plugs or "caps" from the factory, like in the slp conversion kitfor the ls6 intake manifold?? Thanks
06-06-2006, 10:25 AM #2
- Jul 2005
- Jacksonville, FL
LS6 intake swap needs a front coolant pipe, and plugs for the rear from the 01/02 cars for 98-00. Not sure what you're asking.
06-07-2006, 05:47 PM #3
- May 2006
- calif
dwd- wdwd
HI, thanks for answering, I thought knowbody out there would know.. What i'm trying to figure out is did the factory01& 02 ls1's which came with the ls6 manifold have lines that were"capped " from the factory? I guess what i'm trying to figure out is can I swap in the ls6 intake on my 00 vette without the dealer noticing I blocked of some coolent lines( if I used all gm parts ie. caps and coolent line) or did the factory 01-02 engines come with lines capped and my car will then look like the 01-04 ls1 engines?.
06-08-2006, 09:28 AM #4
- Jul 2005
- Jacksonville, FL
My car came with the front coolant pipe/rear plugs from the factory. On 98-00 F cars dealer probably wouldn't notice the coolant pipes, but might see the EGR has been removed. Not sure on the vettes.
Help: coolent smell
By TJKIDD in forum General HelpReplies: 5Last Post: 04-25-2011, 04:56 PM -
oil in my coolent
By jAgZ28 in forum LT1Replies: 1Last Post: 12-09-2010, 09:05 PM -
Low coolent light is on for no reason
By SStatus in forum General HelpReplies: 15Last Post: 07-14-2007, 04:43 AM -
coolent help plz
By rshooch in forum General HelpReplies: 6Last Post: 07-23-2006, 10:02 AM -
Where is the Coolent Level Sensor on 98 Z28 ?
By samualt in forum General HelpReplies: 1Last Post: 06-01-2006, 01:58 AM
