Results 1 to 16 of 16
01-20-2006, 07:12 AM #1SStatusGuest
Low coolent light is on for no reason
My coolent light comes on and stays on for five minutes just like it is supposed to when the coolent is low. So i check the coolent level and its fine. I even top it off just to see if it would change anything. Nothing happened, it still comes on. About three weeks ago i had my system flushed and refilled with dex-cool and I'm guessing that this has somthing to do with what is going on. Anyone ever run into this or have any ideas?
01-20-2006, 07:15 AM #2Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
There is a sensor that might be bad. Try changing that and see what happens.
01-20-2006, 11:40 AM #3Junior Member
- somewhere
Black- A car
Common problem. The orange coolent will gunk up over time if not changed at the proper interval. You'll probably have to get the system flushed and change out that sensor. Another thing that happens when it starts to get like that is the heater core gets clogged. If you're not getting the heat you should, take off the heater core and back flush it to get the gunk out.
01-20-2006, 12:09 PM #4Senior Member
- Jul 2005
- Jacksonville, FL
The low coolant sensors fail all the time, you can try taking it off and cleaning it, or just unplug it and the light will stay off permanently (think they're about $55 at the dealer if you want to replace it). Since you just had a flush they may not have gotten all the air out of the system - but if you've been checking it and the level is still OK, and no overheating problems probably just the sensor. It's on the passenger side of the radiator, about 4-5" below the radiator cap. GM did away with them on our cars starting in 2K.
01-22-2006, 05:26 AM #5Junior Member
- somewhere
Black- A car
Go to www.shbox.com. I think there is a procedure there for removing and reinstalling the sensor.
07-23-2006, 03:57 PM #6Member
- Jul 2005
- commerce twp michigan
07-23-2006, 08:13 PM #7
I would start cheap and make sure there's no air in the system first.
07-24-2006, 04:53 AM #8Member
- Jul 2005
07-24-2006, 07:36 PM #9
my friend has a lt1 and he just foundout today he has a bad sensor
07-12-2007, 11:18 AM #10Junior Member
- Jul 2007
- Des Moines, IA
Blue- 1999 Camero SS
I have this same problem right now with my Camero LS1 99 SS. I have flushed the system, replaced the sensor and made sure the fuilds are full, all is ok but the damn light keeps coming on after I start it.
I have noticed that sometimes after I drive the car for a while and get gets hot and I shut the motor down and turn it back on, the light will stay off.
Short??.. or could it be that the gunk is still stuck around the float in the raditor?
07-12-2007, 12:03 PM #11
07-12-2007, 12:11 PM #12Member
- Oct 2006
- Oklahoma City
00 LS1, WS6, V8 Gremlin- 96 & 98 GTPs, 64 'Cuda
Those sensors really can be a pain. I've had some limited success in the past whapping them with a screwdriver.
07-12-2007, 12:22 PM #13Junior Member
- Jul 2007
- Des Moines, IA
07-13-2007, 09:52 AM #14Senior Member
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
just unplugged mine when I was having this problem, zip tied it out of the way and left it. No more little red light now.
07-13-2007, 11:22 AM #15
07-14-2007, 04:43 AM #16Senior Member
- Jul 2006
- indiana
It is easy to check though, I probably would have changed the sensor if this was still my daily driver but it isnt. So I occasionally check it before I drive it.
Help: coolent smell
By TJKIDD in forum General HelpReplies: 5Last Post: 04-25-2011, 04:56 PM -
oil in my coolent
By jAgZ28 in forum LT1Replies: 1Last Post: 12-09-2010, 09:05 PM -
coolent help plz
By rshooch in forum General HelpReplies: 6Last Post: 07-23-2006, 10:02 AM -
Do all ls1 intakes after 00 come with coolent plugs?
By mach350z in forum External EngineReplies: 3Last Post: 06-08-2006, 09:28 AM -
Where is the Coolent Level Sensor on 98 Z28 ?
By samualt in forum General HelpReplies: 1Last Post: 06-01-2006, 01:58 AM
