Results 1 to 2 of 2
    Member jAgZ28's Avatar
    LINY
    bright red
    1993 z28 camaro
    oil in my coolent
    Ok so what are some possibly reason why there is oil mixed in with my violent. So far I have been told it could be a cracked block, bad head gasket or a clogged Pcv causing blow back or blow by. I don't remember what he said exactly. God I hope its the pcv and not the other 2. So what do you guys think? Is there anything else it could be?
    my car is a 93 z28 a4 hooker catback, qtp cutout, k&n cai, vortec elbow, high flow cat, tb bypass, tb airfoil, rk sport ss hood
    Oct 2001
    Colorado
    95 Z28
    In all honesty I doubt it will be anything to do with the PCV system. The cooling system can be pressure tested to help diagnose a head gasket or cracked block issue. Also, drain the oil and see if there is coolant in the oil. That's en even bigger problem.
  1. Help: coolent smell
    By TJKIDD in forum General Help
    Last Post: 04-25-2011, 04:56 PM
  2. Low coolent light is on for no reason
    By SStatus in forum General Help
    Last Post: 07-14-2007, 04:43 AM
  3. coolent help plz
    By rshooch in forum General Help
    Last Post: 07-23-2006, 10:02 AM
  4. Do all ls1 intakes after 00 come with coolent plugs?
    By mach350z in forum External Engine
    Last Post: 06-08-2006, 09:28 AM
  5. Where is the Coolent Level Sensor on 98 Z28 ?
    By samualt in forum General Help
    Last Post: 06-01-2006, 01:58 AM
