Thread: Loud head light noise
11-16-2012, 03:42 PM #1Junior Member
- Jan 2007
- Indiana
Black- 2000 Formula
Anyone ever have the following issues? If so, what is the cause and fix?
1. When I lower my lights there is a loud grinding noise.
2. When I hit the lock or unlock the car via key less the head lights pop up and go down with the grinding noise when the go down.
The lights still work with no issues, but wondering what is going on.
Thanks
11-16-2012, 04:09 PM #2Senior Member
- Apr 2010
- Alabama
The gears in the headlight motor is bad. Change it out with a brass one instead of a plastic one that came factory.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
11-16-2012, 04:13 PM #3
Firebird Headlight Motor Gears by Rodney Dickman Here's what you need. Works like a charm.
11-16-2012, 07:31 PM #4
Yup headlight gears are gone. I also took my car in to get a $40 part installed into my alarm to get my headlights from going up and down every time I engage or disengage my alarm. That way the gears aren't having so much wear and tear on them.
11-17-2012, 04:41 AM #5
11-17-2012, 06:52 AM #6Junior Member
- Jan 2007
- Indiana
Black- 2000 Formula
Thanks for the info.
- - - Updated - - -
11-17-2012, 05:44 PM #7
11-19-2012, 10:59 AM #8
If you want an easier way out, there's a way to rotate the gear 180 degrees so that the unstripped part of the gear is now in use instead of the already used up bad side. Took me a half an hour to do.
rear end loud noise
By ice97ta in forum GTOReplies: 15Last Post: 10-28-2012, 09:06 AM -
loud screeching noise
By edrvsqz1980 in forum Firebird / WS6Replies: 6Last Post: 06-16-2012, 06:29 AM -
Loud squaling noise
By RedSuperSport in forum General HelpReplies: 6Last Post: 12-05-2011, 11:57 AM -
Loud Thunking Noise When Braking
By Banshee1967 in forum General HelpReplies: 5Last Post: 09-10-2008, 08:47 AM -
Loud Squeeking Noise!
By justinlandis in forum Suspension and HandlingReplies: 1Last Post: 10-04-2006, 05:32 PM
