Thread: loud screeching noise
06-15-2012, 10:41 AM #1
Ive noticed that my car has been making a loud screeching noise everytime i turn it on. I replaced my serpintine belt and ac belt with gatorback, so i first thought it was the belt. I started to trouble shoot the problem and figured out that it only screeches only when i have the a/c on. It will do it for about 3 to 5 min of turning on and eventually go away. Anyone know what this might be?
06-15-2012, 02:56 PM #2
A/C compressor is probably dieing..
Possible compressor clutch issue also.
GM A/C setups are nothing short of junk on many makes and models.
06-15-2012, 05:43 PM #3Magnaflow Quad Tip, Lid, SBellow
UMI: FTC, FSB, RSB, LCA's, PBAR, SFC's, T-Arm w/relo, D/S Loop
Kooks LTH, 3" YP, H/F Cats
Custom Grind Cam, Stall, 3:73 rear
Bilsteins w/Strano Springs Conti Super Contacts
TuneByFrost MSD Wires
Cross Drilled/Slotted Rotors w/Ceramic
06-15-2012, 07:13 PM #4
Im having the same issue on my 96 Z LT1, my father and i diagnosed it as the a/c clutch. As said, gm isnt too awesome with a/c, so what im posting for is to ask if anyone knows whats involved in either fixing the A/C clutch, or doing a delete and being rid of the whole head ache altogether?
Any advice would be great
06-16-2012, 04:29 AM #5
You are going have to replace the a/c itself to fix it. A new one is not cheap, but you may be able to find a use one on the boards. I just did a a/c delete, and it's not hard. Just drain the freon out, them unbolt the system, you will have the hardest time with the condenser in front of the radiator, but it's not too bad.
02 Z28/LS1 NBM - TIN CAN RACING
Full bolt on, weight reduction mods, dyno tuned by FROST = 330hp/342tq New PB = 12.74 @109
06-16-2012, 06:25 AM #6
Not to mention that the A/C compressor is mounted tight to the framerail. I made a half ass attempt to remove mine when I swapped out the K-member in order to gain better access to the motor mount and through bolt. Gave up and went a different direction to do it.
06-16-2012, 06:29 AM #7Senior Member
- Apr 2010
- Alabama
Not to hi-jack this thread but if the condenser is the hard part I am ahead of the game, I removed that when replacing my radiator. I am going to have a shop bleed my ac so I can remove it and do this the legal way. My clutch on my ac is on it's way out so that is my reason for removing it.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
Help: Loud head light noise
By sage210 in forum General HelpReplies: 7Last Post: 11-19-2012, 10:59 AM -
rear end loud noise
By ice97ta in forum GTOReplies: 15Last Post: 10-28-2012, 09:06 AM -
Loud squaling noise
By RedSuperSport in forum General HelpReplies: 6Last Post: 12-05-2011, 11:57 AM -
Help: Engine Noise Help-loud Hiss
By BirdFlewLS1 in forum Firebird / WS6Replies: 3Last Post: 05-14-2008, 01:41 PM -
Loud Squeeking Noise!
By justinlandis in forum Suspension and HandlingReplies: 1Last Post: 10-04-2006, 05:32 PM
