    Member RedSuperSport's Avatar
    Aug 2011
    Kentucky
    99 SS
    Loud squaling noise
    So I started my car up last night and it was making a God awful noise, like a bad belt or a pulley needing lubed, but the more I listened and tried to fund the location it sounded like it was coning from the driver side of the car, by the head under the cowl, any ideas? The Boise almost started to sound like a metal ball bearing in a metal tube moving back And forth squeking and increasing speed as i raised the rims. Its a horrible noise
    Sent from my DROIDX using Tapatalk
    Aug 2011
    Kentucky
    99 SS
    Pardon the spelling I typed it as soon as I woke up, ill try and post a video tomorrow
    Aug 2000
    Indy
    tensioner pulley
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    college station, tx
    sold: 1999 firebird
    Quote Originally Posted by Danger731 View Post
    tensioner pulley
    agreed, lube the tensioner. if that doesnt work change the belt, cheap and easy.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Pinpointing a noise, especially a rotating one, under the hood can be deceiving. So, like the rest, I assume a pulley/belt issue.
    Try working the tensioner back and forth, hit it with some lubrication (don't get any on the belt) and see if that cures it. If it reduces the noise, you know you have a bad tensioner pulley or bad belt.
    (You could try belt dressing at this point, but I don't use it and am not going to recommend it for that reason)
    Next would swap the belt(s) out for gatorback and gatorback only.
    If you still have a rotating noise after that, it's most likely time to replace pulley's. Idler first, then the tensioner. Hopefully you don't have to go any further than that, as it will start to get pretty pricey.
    Use a redneck stethoscope - take a long screw driver or a long metal rod and place it on each rotating part as the car idles. Next place it to your ear. You'll hear noises, move to each rotating pulley wheel or tensioner. When you get to the one that is squealing really loud compared to the others that is the bad part. The bearings will either be really loud or it will sound like they are grinding. Either way it will sound much different when compared to the others.
    Please be careful.
    Here is a video that will show you what a mechanical stethoscope is and how to use it. Fast forward to 1:50
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I agree with all of the above. Mine squeals when it is humid or raining. I have to change out my belts soon.
  1. rear end loud noise
    By ice97ta in forum GTO
    Last Post: 10-28-2012, 09:06 AM
  2. loud screeching noise
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 06-16-2012, 06:29 AM
  3. Loud ticking noise after cam install
    By gunguyWS6 in forum Internal Engine
    Last Post: 11-01-2007, 04:05 PM
  4. Loud Squeeking Noise!
    By justinlandis in forum Suspension and Handling
    Last Post: 10-04-2006, 05:32 PM
  5. Loud noise when I turn Left?
    By 97BlackT/A in forum Wheels and Tires
    Last Post: 10-24-2005, 11:58 PM
