Thread: Loud noise when I turn Left?
08-08-2005, 05:59 AM #197BlackT/AGuest
When I make a left turn, I have this loud noice coming from the drivers side rear wheel. I have had a guy that works on rear ends, and he said that the rear end is good. So, I have no idea whats going on. I am really getting pissed off because it make smy car sound like SH!T. Does anyone know what I can do to fix it or make it stop for a while. Thanks!!!!!!!!
08-08-2005, 09:48 AM #2extxdpscamaroGuest
I know it sounds pretty lame but what do your rear sway bar bushings look like? Also what kind of sound is your car making? Clunk or a whine?
08-10-2005, 08:59 AM #3Junior Member
- Chicago
Black- 1997 Camaro SS
check your rotors and brake pads. that happened to me for a long time. changed out my rotors and problem went away.
08-25-2005, 06:29 PM #4Cappin_StabbinGuest
this happened to mine once, it turned out that the wheel was slightly bent. Once i got a new wheel it was right as rain.
09-23-2005, 04:27 PM #5Junior Member
- Akron, Ohio
Black- 1998 SS Camaro
I've had GM pads wear uneven and grind while turning. New pads and rotors fixed the problem.
09-24-2005, 03:55 AM #6Grand Imperial Wizard
- Retired Outlaw Sum Bitch
I had a wheel bearing go south and did just that.
09-25-2005, 12:41 AM #7FlewbyurGTGuest
could be anything...i had the same problem...does it do it if the clutch is in(if u have 6 speed)...but mine did it and it was the rear end..only made lunk when i turned i think it was left...there is no way to tell if the rear is going out without taking it apart and looking...but it was my spider gears..some of the teeth broke and put stress on it in a turn..so like i said..could be anything
10-09-2005, 04:39 PM #8Junior Member
- Oct 2005
- St. Louis, MO
- 2001 Corvette M6
my old 96 ta was doing something like that and when I changed out the rotors and pads it went away....
10-24-2005, 11:58 PM #9
Brake squeal
GM makes a caliper bracket shim kit for f body rear ends with disc brakes. The axle endplay makes the rotor hit the caliper bracket in U turns. My 96 did it until I put in the shim kit.
Clicking sound when I turn my wheels left or right.
By Street Fighter in forum General HelpReplies: 10Last Post: 05-22-2015, 03:50 AM -
Loud squaling noise
By RedSuperSport in forum General HelpReplies: 6Last Post: 12-05-2011, 11:57 AM -
loud tranny sound, now car won't turn over?
By nomorefords in forum Automatic TransmissionReplies: 3Last Post: 03-06-2008, 12:32 PM -
Left Turn Signal Problem
By 6speedTAthistime in forum Firebird / WS6Replies: 6Last Post: 11-21-2007, 06:53 PM -
Loud Squeeking Noise!
By justinlandis in forum Suspension and HandlingReplies: 1Last Post: 10-04-2006, 05:32 PM
