Results 1 to 16 of 16
    oceanside ca
    06 GTO
    rear end loud noise
    Hey guys, last couple days, when my car gets warmed up, driving down the road, there is a random popping in the rear end, stoping and starting again does it real bad. its very loud and can actually feel it sometimes. any idea what it is. read a few things saying to change the fluid out, any other advice would be great.
    Pittsburgh
    2008 Hummer H3
    Dead/dieing 10-bolt. Time for a 12-bolt or a 9in.
    Your friendly policeman FinZ28's Avatar
    Jan 2012
    Alabama
    Bright Rally Red
    2001 Chevy Camaro Z28
    Are you sure the noise is from the housing itself, and not a suspension-related issue? I'd start checking suspension components like LCA's, Panhard rod, sway bar and so on. I'd also check where the torque arm mounts to the rear-end.
    2001 Chevy Camaro Z28 A4
    SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Bye bye 10 bolt. Rip
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    We need more info. Such as:
    Mileage
    Is it a popping noise? Or a clunking noise?
    Is the rear end howling while driving?
    You could have a bad/worn cradle bushing or differential bushing or U-joint that is transmitting the noise into the cabin. Put the car on a lift and change out the fluid and get back to us. Remember 75-140 SYNTHETIC with some friction modifier added to it.
    Another thing: Is the rearend leaking where the drive shaft goes in? Around where the half shafts go in? Check your half shaft bolts as well.
    oceanside ca
    06 GTO
    Its got 65k miles on it, and its more of a popping sound. had it up on the lift earlier today, and didnt see any leaking as far as i could tell. as far as the howling, and i have not heard any whining or howling when driving. ill be doing the fluid this weekend, and ill post up if anythign changes.
    North Jersey
    2004 GTO M6
    Ok. Keep us posted.
    oceanside ca
    06 GTO
    after a rough weekend, finally got to get the fluid changed today. drove it for a good 30 min, and it seems everything is fine, thank goodness i dont need to replace the rear end. thanks for the help guys.
    North Jersey
    2004 GTO M6
    Ok. Good to hear. Give us a shout if you need anything else. Sounds like your rearend fluid was breaking down causing the clutches in the diff to chatter.
    Member pmolina0436's Avatar
    2004 GTO
    I have a similar problem as well..I have changed my diff...oil and still the same...mine is more like a thud...I can certainly feel it...coming to a stop...sometimes I feel it from the rear and sometimes from the front...I always thought it might be. Something with the transmission cause I. Feel the thud sometimes when it downshifts..clueless on what could be causing it..
    A mechanic told me it could be the rear shocks...changed those out...and th same thud...anyone know what it can possibly be?
    Indianapolis
    2000 WS6 6spd Hooker LT
    Mileage
    Do the GTOs use 75-140?
    Member SuperSSguy's Avatar
    Jul 2012
    NorCal
    Sunset Orange Metallic
    2002 Camaro SS M6
    Quote Originally Posted by pmolina0436 View Post
    U-joints maybe? anyone else?????
    North Jersey
    2004 GTO M6
    04-06 GTOs run 75-140 and I believe a pint of friction modifier as required by GM. I believe GM has since discontinued the friction modifier but there is something called TRU GEAR by, I believe, CRC.
    Pmolina- have you checked the rubber bushings that connect the driveshaft to the trans and diff?
    Pittsburgh
    2008 Hummer H3
    oops,,its a gto my bad..
    Member AKA Speedy's Avatar
    Oct 2009
    Elizabethtown, KY
    Spice Red Metallic
    2006 Pontiac GTO
    Quote Originally Posted by SuperSSguy View Post
    I had a very similar problem... turned out it was a twist in my passenger half shaft. barely noticeable without a thorough inspection. replaced it and everything has been fine since.
    Oct 2012
    ardmore oklahoma
    yellow
    2004 pontiac gto
    those sucky gto driveshafts. i put in a solid driveshaft in my 04 gto. what a difference it made.
  1. Help: Loud head light noise
    By sage210 in forum General Help
    Last Post: 11-19-2012, 11:59 AM
  2. loud screeching noise
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 06-16-2012, 07:29 AM
  3. Loud squaling noise
    By RedSuperSport in forum General Help
    Last Post: 12-05-2011, 12:57 PM
  4. Very Loud noise coming from trans or rear-end?
    By greenvilleTA in forum Drivetrain
    Last Post: 10-04-2008, 11:14 PM
  5. Loud Squeeking Noise!
    By justinlandis in forum Suspension and Handling
    Last Post: 10-04-2006, 06:32 PM
