    Aug 2006
    Michigan
    98 T/A
    Loud Thunking Noise When Braking
    Whenever I brake repeatedly, I get a grabbing thunking noise from under the car.
    It is not subtle, rather loud.
    Has been getting increasingly worse over the past year.
    Thoughts?
    here
    2001
    torque arm bushing?...........i had a caliper come loose also and it made a clunk sound,but it fell off before a year...
    Member Mr Z's Avatar
    Idaho
    1998 T/A A4
    Yea I had a clunking noise in the front of the car whenever I'd brake for the first time in a new direction (such as backing out a spot and stopping to go forward). Turned out it was a loose caliper bolt that i neglected to tighten.
    Aug 2006
    Michigan
    98 T/A
    Thanks for the replies...
    Without getting under the car yet...When I start/travel in reverse, I hear the thunk. Not when I go forward. When I brake going forward, I hear the thunk. When I start/travel in drive, I do not hear the thunk.
    Idaho
    1998 T/A A4
    That's exactly what I would hear. I'd back out of a spot and when I slowed down to go forward, it'd clunk. and then when I'd start driving forward and slow down for the speed bump in my apartment complex, there'd be another one. But afterwards I wouldn't hear another one until it came time to back into my spot. I had it clunking for a while before I found it. Even had the dealership look into it and started telling me all this bs about having a crack in my lower control arm (which I sure couldnt find...) and to let them replace it. But I tightend my caliper bolt and it has been gone for over 4 months.
    Aug 2006
    Michigan
    98 T/A
    Ha! Found the problem...for now.
    The two bolts that hold the torque arm to the differential were loose. Overlooked it.
    All well now! Thanks!
    Will be replacing the bushings though soon.
  1. rear end loud noise
    By ice97ta in forum GTO
    Last Post: 10-28-2012, 09:06 AM
  2. wierd grind noise when braking
    By flybird in forum General Help
    Last Post: 06-26-2012, 01:17 PM
  3. loud screeching noise
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 06-16-2012, 06:29 AM
  4. Loud Squeeking Noise!
    By justinlandis in forum Suspension and Handling
    Last Post: 10-04-2006, 05:32 PM
  5. Clunking noise from front suspension when braking
    By RchZ28 in forum Suspension and Handling
    Last Post: 12-08-2005, 05:00 PM
