    Junior Member danjo11's Avatar
    May 2011
    Kentucky
    Victory Red
    2000 SS
    Vacuum leake on 97Z
    I need to know the best way to check for an air system Vacuum leak. I have recently replaced a couple O2 Sensors and both ERG valves. I am still getting codes for a vacuum leak. (the gas cap is fine). Can someone point me in the right direction on how to check for a leak? Thanks for the help.
    Junior Member murche's Avatar
    Feb 2008
    Fairfield, CA
    Green
    93 Camaro
    shbox.com has some vacuum diagrams. Get a hand vacuum pump with a gauge from an auto parts store for about 20 bucks, isolate lines and start checking for leaks
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Isolate each line and spray with starting fluid. When the idle raises, you'll be able to pinpoint the leak.
    Flower Mound
    1997 Z-28
    x2, shouldn't take very long. Might also want to spray along intake manifold, but FYI if your's is painted it will take the paint off and you will be doing some touch up.
    Waiting on the Tree transamtom's Avatar
    Niagara Falls Ont.Canada
    1999 TA A4
    Both EGR's?
    There is one EGR on the back driverside of the intake.
    Do you mean the Air Diversion Valves on the exhaust manifolds?
    The intake manifolds are notorious for leaking at the back.
    They cast the drip rail on the manifold too short and you blow the RTV sealant out.
  1. Help: Vacuum source
    By Wagonmaster in forum General Help
    Last Post: 11-29-2014, 09:36 PM
  2. Help: Trans Am engine Vacuum line for Vacuum/Boost Gauge
    By 1batt4u in forum General Help
    Last Post: 11-13-2014, 06:42 PM
  3. Question: About crankcase vacuum
    By 01NavyBlueSLPSS in forum Internal Engine
    Last Post: 04-25-2011, 07:16 AM
  4. Vacuum Leak from EGR
    By jpn8801 in forum General Help
    Last Post: 04-21-2011, 06:59 PM
  5. Vacuum gauge
    By CKramer in forum General Help
    Last Post: 05-08-2006, 03:43 PM
