Results 1 to 1 of 1
Thread: Vacuum Leak from EGR
04-21-2011, 05:59 PM #1
I thought i would have to buy the hose going from the plenum to the EGR then to the passenger side exhaust manifold.. @ $125 that better fix the problem right?
How I came to this conclusion was people here were saying there is NO gasket that goes to that pipe to seal it. They were wrong! Their IS a gasket, its PART # 70895. I'ts a FEL-PRO #. When you remove the one 10mm nut to remove the EGR pipe from the plenum, it sits underneath the metal piece at the top were the bevel is.
I did that, started it up, Prrrrrrrrrs like a kitten
If you have a vacuum leak there, check that gasket, a $2 part is a HELL of alot better then spending $125 on miss information
just my $.02
Vacuum leak
By 00hawk109 in forum General HelpReplies: 6Last Post: 07-17-2011, 09:39 AM -
Vacuum leak or not?
By soop in forum General HelpReplies: 8Last Post: 02-07-2011, 11:56 PM -
Vacuum leak
By blackbird0230 in forum External EngineReplies: 3Last Post: 04-25-2010, 08:39 PM -
Possible vacuum leak?
By shaggsm3ls1 in forum General HelpReplies: 11Last Post: 10-06-2009, 11:14 AM -
Help: Vacuum leak (I think)
By clow76 in forum General HelpReplies: 7Last Post: 08-12-2009, 03:21 PM
