Thread: Vacuum leak (I think)
08-11-2009, 01:48 PM #1
I popped my hood today while the motor was running and heard a hissing sound obviously, what i think is a vacuum leak. Its a hard line wrapped in black foam running under the fuel rail on the passanger side of the the motor next to the tune port intake, it goes into a black rubber hose fitting into the intake right behind the throttle body, thats what has the hole in it and is leaking.I posted pics of the hose with the hole in it, it has the red straw sitcking out of it.Somebody HELP!!!!!!!!!Thanks
[/IMG]
08-11-2009, 01:55 PM #2
go to photobucket.com and become a member it's free then upload your pics then copy the img code and paste it in your post that should take care of your picture problem
08-11-2009, 02:14 PM #3Custom Painter/Tech
- May 2009
- Plainwell, Mi
Flame Red / Orange Custom- 1998 Trans Am
yeah thats your PCV Valve hose and they can tear easily or at least mine did when I took my motor appart but the only replacement I have found was like $118 so I just used some RVT to try and seal it up but it dose not work that good I sugest not doing this try and find a new PCV hose and if i find one i'll let ya know.
98 Trans Am Custom Paint, Ghost Skuls On Racing Stripe + Custom Front Lip, :MODs Tubular K-member, Tubular Upper and lower A-arms, Tubular Control Arms, 4:10's, Cam L-.567/.575 [email protected]/.218,1.85 Roller Rockers, P&P Heads, ARH Headers & HF Cats & Y-Pipe, SLP loudmouth catback, +'s
08-11-2009, 02:22 PM #4
I had the same problem when I bought my car I just cut that part off and stuck the hose back in. it holds up great. You will have to buy the entire hose to fix it or you could just rig it like I did.
1999 A4 WS6 Pewter, Hooker Long Tube Headers ,GMMG Catback Exhaust, QTP Off-road catted y-pipe, K&N FIPK Intake, GM 3.73's, Spohn Torque Arm,BMR LCA's Dyno Tune by PBJ.
08-11-2009, 02:24 PM #5Custom Painter/Tech
- May 2009
- Plainwell, Mi
just found a good thread try this out let me know if it helps. >>>>>>PCV Valve Recommendation / Housing Modification
08-11-2009, 03:06 PM #6
Thanks guys looks simple enough to fix. I appreciate all the post replies.
08-11-2009, 03:54 PM #7
08-12-2009, 03:21 PM #8Just a farmboy
- Jun 2007
- Montpelier, VA
Pewter- 2000 Pontiac Trans Am
mine got a hole in it, i used electrical tape to fix it, just wraped it 5 or 6 times, that was last year, still holding good.
Vacuum leak
By 00hawk109 in forum General HelpReplies: 6Last Post: 07-17-2011, 09:39 AM -
Vacuum Leak from EGR
By jpn8801 in forum General HelpReplies: 0Last Post: 04-21-2011, 05:59 PM -
Vacuum leak or not?
By soop in forum General HelpReplies: 8Last Post: 02-07-2011, 11:56 PM -
Vacuum leak
By blackbird0230 in forum External EngineReplies: 3Last Post: 04-25-2010, 08:39 PM -
Possible vacuum leak?
By shaggsm3ls1 in forum General HelpReplies: 11Last Post: 10-06-2009, 11:14 AM
