Results 1 to 20 of 29
Thread: Vacuum source
    Junior Member Wagonmaster's Avatar
    Aug 2008
    So. Fla.
    Black Cherry
    1939 Chevrolet
    Question Vacuum source
    Hi folks! I've looked through the stickies and didn't see what I need....I installed a Gen III 6.0 (LQ4) truck engine into my 1939 Chevy and need a vacuum source for my power brake booster. Any ideas where to look for this?? These things don't have a lot of removable plugs like the "old" 350's and 327's, etc....
    Thanks for looking.
    Joe
    Track Whore 570SX's Avatar
    Central Florida
    1989 Nissan 570SX
    look on the intake manifold. there are ports on it, on the back and up front by the throttle body. really any of them will suffice, but there is one on the back made specifically for that purpose.
    how did you not see them? if you didn't cap off the unused ones (which there must be, because '39 had no emissions standards), your idle would be really high if it would idle at all. or have you not started/run it yet?
    ~Jason
    2005 Acura RSX: Daily Driver duties
    1994 Toyota Corolla: the beater that just won't die!
    "Fast, Cheap, Reliable. You can only have two."
    Aug 2008
    So. Fla.
    Black Cherry
    1939 Chevrolet
    Cool vacuum
    It runs, we drove it home, albeit w/o and power assist for the brakes. The computer is hunting for the missing O2 sensors. (no exhaust from headers to mufflers, yet..Considering that it's okay. There are NO plugs on this intake. The place on the back where trucks take vacuum (most are hydro-vac) is blocked off and no others in sight!! There are none used or unused, other than the one I spoke of. Remember, this isn't an LS1....
    Can you get me a picture of where the intake is blocked off?
    That seems odd to me.
    Aug 2008
    So. Fla.
    Black Cherry
    1939 Chevrolet
    Thumbs up
    http://www.chevyavalanchefanclub.com...html#msg717399
    This is the link to intake manifold replacement on the 6.0 Avalanche type engine (LQ4) that I have. The second photo shows where a power brake booster should hook up. The unit my engine came from had a hydro vac system, not a booster, so this fitting is blocked. I'm sure it can be removed ( I didn't see this when I first posted), but it is plastic, and I don't want to break or otherwise damage the intake. I plan to run it, since tests show that it makes big torques, and this is a street car, that will be a cruiser and sometime tow my Utility trailer and H-D.
    Thanks for your assist.
    Central Florida
    1989 Nissan 570SX
    yeah, i'm also wondering what you mean by "blocked off." also, there is a port on the top of the truck intake manifold, right in the middle. at least on ones i've seen.
    Aug 2008
    So. Fla.
    Black Cherry
    1939 Chevrolet
    Blocked port
    Here is a pic of the intake and the port that I am talking about. There is a yellow circle that shows the port and the plug blocking it.
    [IMG][/IMG]
    have you looked at that plug closely to see if you can tell how it's mounted in there? Sure would be nice if it was threaded but it's probably epoxied. Might have to hit a junk yard and find one with the open port there. If you're to that point I'd probably try to get that plug out one way or another before heading to the yard. Might get lucky and be able to get it out.
    Aug 2008
    So. Fla.
    Black Cherry
    1939 Chevrolet
    Thumbs up Plug
    Good advice, thanks. I have ordered the factory plug for a vehicle with a power brake booster. When I get it, I will then know how it is attached. Short term, I have spliced the larger hose to a smaller one and attached it to a small port on the right side of the manifold at the top.
    Appreciate everyones advice and assistance.
    good luck and keep us updated. Make sure you have good vacuum on that booster, not something you want to discover coming to a red light.
    Aug 2008
    So. Fla.
    Black Cherry
    1939 Chevrolet
    Talking "Good" vacuum
    Indeed! For a small diameter line, the cars stops amazingly well...Not ready to go road racing yet, but hauls it down just fine![IMG][/IMG]
    nice looking ride
    Central Florida
    1989 Nissan 570SX
    another reason manual brakes are nice
    Aug 2008
    So. Fla.
    Black Cherry
    1939 Chevrolet
    Probably okay for your light weight. Not so for my sedan that will pull a trailer on occasion.
    I have found a factory power brake port, as indicated above. Now I have the fitting that goes there and will install it as soon as I can figure out how to remove the existing plug without damage. It would appear that it epoxys into place since there are no threads or grooves.
    Quote Originally Posted by Wagonmaster View Post
    can you drill it out? Would have to take care not to get crap down into the intake and I'm not familiar with those intakes but if you could drill that plug out and not get crap inside it that may be your answer.
    Aug 2008
    So. Fla.
    Black Cherry
    1939 Chevrolet
    Cool Drill??
    If I have to.... I hope I won't need to. The plug in the rear of the intake has GOT to be removed somwhow, I'm hoping for a better way. Someone with more experience on these "plastic" manifolds may have the right method.
    Thanks for your advice....
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Its because the engine is out of an HD truck that has hydroboost hydraulic powered brakes instead of vacuum powered brakes. So the vacuum port on the manifold used for the brake booster is capped off from the factory.
    Aug 2008
    So. Fla.
    Black Cherry
    1939 Chevrolet
    Question Yes it is!
    Thanks...I get that, but the issue is how to remove it, and install the fitting for the vacuum booster. If you can help with this, please let me know!
    [IMG][/IMG]
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    It looks like you could just cut off the end plug and slip a hose on there. Can you take a closer picture of the plug?
    Aug 2008
    So. Fla.
    Black Cherry
    1939 Chevrolet
    Plug
    Harder to see with the motor in the car...wish I'd taken a better pic when it was on the trailer, after we pulled it from the donor..... It isn't a "male" type plug. it is pretty much flush with the intake.
  1. Help: Trans Am engine Vacuum line for Vacuum/Boost Gauge
    By 1batt4u in forum General Help
    Last Post: 11-13-2014, 05:42 PM
  2. The Source
    By Nhra Firebird in forum Almost Anything Goes
    Last Post: 10-07-2012, 05:12 PM
  3. Need help from an outside source
    Last Post: 01-14-2010, 10:12 AM
  4. Key-on power source?
    By bluefields88 in forum Stereo and Electronics
    Last Post: 07-02-2009, 01:52 PM
  5. Need source for EGR block off for LS1
    By Jglisson in forum External Engine
    Last Post: 10-07-2007, 01:18 PM
