10-07-2007, 05:46 AM #1Junior Member
- Oct 2007
- Yulee, FL
Need source for EGR block off for LS1
I used to seem them on Ebay for around $25, but I don't see any now. I need an EGR block-off kit for a 1999 Trans Am with LS1. Thanks....
10-07-2007, 07:47 AM #2
http://www.ls1.com/forums/showthread.php?t=63611
you can also just use an expandable freezeout plug for the intake in addition to those exhaust block off's
10-07-2007, 10:22 AM #3Junior Member
- Oct 2007
- Yulee, FL
Orion,
Thanks so much for the info. I also checked out Speed Inc. The best I can understand I need the following for the complete EGR delete:
Speed Inc
Emissions Block-off Plates
CNC Machined, perfect fit, elimate your EGR on 98-00 cars and your A.I.R. injection tubes on 98-02 cars. EGR Plug: Plugs the hole in your F-body LS1 intake when eliminating the EGR. Simply "taps" into place.
Off-Road Use Only
item no description price buy
SS198 LS1 EGR Header Block-off Plate $8.00 buy
SS298 LS1 AIR Block-off Plates $8.00 buy
SS398 LS1 EGR/AIR Block-off Set $14.00 buy
SS498 LS1 EGR Manifold Plug $2.00 buy
Is this correct?
10-07-2007, 01:18 PM #4
Are you just getting rid of the EGR or the AIR system as well? If just the EGR you need only the SS198 LS1 EGR Header Block-off Plate and the $2 plug. If you are getting rid of both you need the SS398 LS1 EGR/AIR Block-off Set and the plug.
Help: Vacuum source
By Wagonmaster in forum General HelpReplies: 28Last Post: 11-29-2014, 08:36 PM -
The Source
By Nhra Firebird in forum Almost Anything GoesReplies: 4Last Post: 10-07-2012, 05:12 PM -
Need help from an outside source
By SteveCZ28 in forum Almost Anything GoesReplies: 25Last Post: 01-14-2010, 10:12 AM -
Key-on power source?
By bluefields88 in forum Stereo and ElectronicsReplies: 4Last Post: 07-02-2009, 01:52 PM -
Need a P/S pump source
By shaggsm3ls1 in forum CorvetteReplies: 0Last Post: 01-19-2008, 11:10 AM
