    May 2010
    Queens, NY
    2000 Trans Am
    Trans Am engine Vacuum line for Vacuum/Boost Gauge
    I have an electric Auto Meter Vacuum/Boost gauge.
    Where is a good spot to tap into the vacuum line? A T fitting is already included with the Auto Meter gauge kit.
    Is this a good spot to tap into circled in red??
    Nope. Go to the back of the intake, passenger side, and you'll find a line there. Other option is the vacuum supply to the secondary air solenoid on top of the manifold, driver side (which sources from the first option).
    May 2010
    Queens, NY
    2000 Trans Am
    You mean all the way in the back? Do you have a picture or diagram exactly where the line is, easy to get to?
    Thank you!
    Getting ready for work right now, but if you go to the back of the engine bay, on the passenger side, it's the only small diameter vacuum line back there. I believe it connects to the MAP sensor which is plugged into the back of the intake on that side. Not easy to get to or see with the cowl...
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    I plugged my autometer vac/boost gauge in the same spot as in the picture. Is that a bad spot where I will get a false reading? It seems to register correctly for booth vac/and boost. That is where the factory uses the vacuum for the valve covers.
    May 2010
    Queens, NY
    2000 Trans Am
    Isn't it the same vacuum line from the picture I posted, circled, going straight to back of the intake, as per a vacuum diagram I came across?
  1. Vacuum Line Question
    By jfl330 in forum External Engine
    Last Post: 06-29-2012, 01:39 PM
  2. Vacuum Line Connections...
    By Rick@Metco in forum General Help
    Last Post: 10-12-2010, 03:15 PM
  3. Question: 99 3.8 V6 MAP vacuum line?
    By SSTODD in forum V6
    Last Post: 02-20-2010, 08:40 AM
  4. Boost Gauge vs Boost/Vacuum Gauge
    By ls1camino in forum Forced Induction
    Last Post: 09-28-2008, 06:02 PM
  5. Vacuum gauge
    By CKramer in forum General Help
    Last Post: 05-08-2006, 02:43 PM
