Results 1 to 2 of 2
Thread: 99 3.8 V6 MAP vacuum line?
07-22-2009, 10:05 AM #1MOTOR CITY MARO'
- Nov 2005
- LIVONIA,MICHIGAN
PEWTER- 2000 CAMARO SS #3821
Does anyone know if a vacuum line goes on the front facing MAP port on a firebird 99 3.8 and where it goes to? My buddy swapped 3.8's and has that port open and cannot remember where it might go/be. The rear port goes around the back of the intake to the fuel/evap maybe. He thinks it might go to the auto trans.
02-20-2010, 08:40 AM #2
The front facing port on the MAP actually comes out there and then the vac hose turns under the MAP and goes back to the tranny.. Besides the brake booster vac hose there are only 2 other vac lines on our fly by wire 3800II's. The rear line on the MAP goes around the back and over to the Fuel pressure reg..
PS. I know this thread is old but I figured someone else could use the info as well.
Help: Trans Am engine Vacuum line for Vacuum/Boost Gauge
By 1batt4u in forum General HelpReplies: 5Last Post: 11-13-2014, 05:42 PM -
Vacuum Line Question
By jfl330 in forum External EngineReplies: 15Last Post: 06-29-2012, 01:39 PM -
Vacuum Line Connections...
By Rick@Metco in forum General HelpReplies: 3Last Post: 10-12-2010, 03:15 PM -
Question about Wiring & Vacuum Line after crash
By tmartinez91084 in forum General HelpReplies: 3Last Post: 07-25-2010, 06:51 PM -
intake manifold vacuum line
By leviathon 88 in forum General HelpReplies: 3Last Post: 08-31-2007, 09:17 PM
