Results 1 to 16 of 16
    Experienced Old Fart jfl330's Avatar
    Mar 2011
    Tampa, FL
    '02 35th SS LE SLP#1084
    Vacuum Line Question
    I am putting my intake back on after replacing the knock sensors. Besides the AIR system, what else connects to that port? I would like to just cap it off on the back of the manifold now as it is easy to get to.
    Jon
    Air Vacuum Hose *, Break booster and HVAC
    The HVAC is the hard small plastic line and it connects to the bottom port.
    You need all of it and will need to connect it all back. unless you don't want breaks or AC?
    * - this is what alldatadiy is calling it.
    Senior Member Z28_Driver's Avatar
    Jun 2009
    Ohio
    Sunset Orange Metallic
    2002 Z28 Hardtop
    that covers it well. no ac sucks. brakes just slow you down anyway
    Mar 2011
    Tampa, FL
    Well I guess I have to provide for the HVAC line, this is Florida, it's 10,000 degrees out!
    But I will kill the AIR System line now instead of going back in later.
    Thanks!
    Jon
    Jun 2009
    Ohio
    2002 Z28 Hardtop
    Quote Originally Posted by jfl330 View Post
    Thanks!
    Jon
    Good man. The AIR system just clutters the engine bay anyway.
    So I understand this straight....
    The 01'-02' has no egr, but still has the air pump system?
    Orlando, FL
    Mean Black
    If you eliminate the AIR just remove the T on the back of the intake and just connect the small line for the HVAC. Is the small tubing going to the passenger side firewall area.
    Orlando, FL
    Mean Black
    that's what im getting.
    Jun 2009
    Ohio
    2002 Z28 Hardtop
    From the factory they have the AIR pump and all the tubing that goes with it.
    Mar 2011
    Tampa, FL
    Quote Originally Posted by Z28_Driver View Post
    Not anymore, nifty pile crap on the garage floor now!
    Jon
    Mar 2011
    Tampa, FL
    Cam change in the 01' & 02' allowed the egr to be eliminated.
    Jon
    Jun 2009
    Ohio
    2002 Z28 Hardtop
    Jon
    Correct.
    Always best to remove dead weight anyway.
    Mustang Eater Ls_won's Avatar
    Feb 2010
    Springfield, Missouri, United
    Maroon
    2000 z28 6 speed
    good deal player
    2001 B4C Totaled 4/25/11
    2000 Z28 M6 Cammed N' Slammed (SVT KLR)
    Senior Member JoshuaGrooms83's Avatar
    Lake Geneva, WI
    98 Trans Am
    hey, quick question, if the vaccum tube that connects to the MAP is damaged (cracked by an idiot installing an LS6 manifold...) will this cause weird running conditions like surgin idling and stumbling when punched at WOT?
    I want to say yes because it is an opening in the vacuum. You can try to get a similar size tubing and try to make a fix.
    Lake Geneva, WI
    98 Trans Am
    yeah, im looking into it. my cars been acting funny and i want it fixed
  1. Help: Trans Am engine Vacuum line for Vacuum/Boost Gauge
    By 1batt4u in forum General Help
    Last Post: 11-13-2014, 05:42 PM
  2. Vacuum Line Connections...
    By Rick@Metco in forum General Help
    Last Post: 10-12-2010, 03:15 PM
  3. Question about Wiring & Vacuum Line after crash
    By tmartinez91084 in forum General Help
    Last Post: 07-25-2010, 06:51 PM
  4. Question: 99 3.8 V6 MAP vacuum line?
    By SSTODD in forum V6
    Last Post: 02-20-2010, 08:40 AM
  5. intake manifold vacuum line
    By leviathon 88 in forum General Help
    Last Post: 08-31-2007, 09:17 PM
