    Rice killa 01NavyBlueSLPSS's Avatar
    Dec 2010
    Washington
    01 Camaro SS M6
    About crankcase vacuum
    I was browsing forums today and I found a thread on bad piston rings. Well in the thread it talked about taking your oil cap and checking for smoke and if there is air or oil blowing out that means the rings are bad. So figured just for shits and giggles I would try it. I was bored. Well good news is no smoke or blowby, but I didn't really feel vacuum. So I put a shop towel over the oil filler and sure enough it dipped down. Vacuum! But I'm wondering: how much vacuum is there supposed to be? Should my crankcase have sucked the shop towel like a shop vac? Lol
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    The little vacuum line behind the TB on the intake, is the breather. It's minimal... That's also how the oil gets inside the intakes...
    Apr 2009
    Pennsylvania
    I just took my ls1 intake off because i am swapping with an ls6 intake and the ls1 intake was full of oil. Now im waiting on the catch can, this should solve the problem.
    Dec 2010
    Washington
    01 Camaro SS M6
    Quote Originally Posted by 1slowbusa View Post
    I ordered a catch can yesterday from the ws6 store. Are you completely removing your pcv system?
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by 01NavyBlueSLPSS View Post
    I was running a Homedepot air drier....my catch can will be at my door today and hope to install it today after work
    Dec 2010
    Washington
    01 Camaro SS M6
    What can did you decide to go with
    mercersburg pa
    hugger orange
    2004
    mercersburg pa
    hugger orange
    2004
    Il probably tear it apart and work a filter into the return line side of the can
    Dec 2010
    Washington
    01 Camaro SS M6
    I was thinking about sticking a little filter on the fresh air hose since I'll be running a single can setup.....
    OP,
    look at this thread. This is 6 weeks after I did the LS6 VCT mod and installed a catch can.
    The CC does catch a lot of oil that would have gone into the LS6 intake.
    http://www.ls1.com/forums/showthread...65#post2629607
    If you got the same CC as me you will not need a breather. It already has a internal filter material that the oil catches on and drips to the bottom from there.
    Dec 2010
    Washington
    01 Camaro SS M6
    OP,
    Haha wow I'm glad I installed mine now
    Royal Oak, Michigan
    2004 GTO A4
    My Pass side valve cover has mad vacuum. It's so bad that I can hardly get the oil fill cap out. In fact, I had a whistling sound coming from the motor. I thought it was a belt slipping. Turns out that it was the valve cover sucking air in through the oil filler o-ring. Is this normal/good or do I have some issue with the intake?
    I corrected the issue by installing a breather filter in place of the oil fill cap. Whistle is gone....
  1. Help: Trans Am engine Vacuum line for Vacuum/Boost Gauge
    By 1batt4u in forum General Help
    Last Post: 11-13-2014, 05:42 PM
  2. Cleaning the crankcase?
    By JWSmythe in forum GM Trucks
    Last Post: 02-08-2012, 06:17 AM
  3. do i need a crankcase breather?
    By bobbyd in forum General Help
    Last Post: 06-09-2011, 02:23 PM
  4. EGR Crankcase fumes
    By Banshee1967 in forum General Help
    Last Post: 02-24-2009, 02:31 PM
  5. crankcase filter
    By SVG210 in forum External Engine
    Last Post: 01-19-2008, 06:39 AM
