Results 1 to 10 of 10
Thread: air check valve pipe
11-23-2009, 11:58 AM #1
I was in the middle of attempting to change the passenger side air check valve due to a p1416 ses code, I unbolted and removed the air check valve and pipe and removed it from the engine to access it easier but after several tries I cannot get the damn air check valve off of the pipe, maybe I am trying to unbolt it the wrong direction or something? I have tried everything even spraying some PB blaster on the treads but it is hopeless it just wont budge, can you just buy another pipe and gasket at maybe a local Autozone or something? I am just really frustrated and want to get this fixed, thanks.
11-23-2009, 12:57 PM #2
I tried it one last time and actually got them apart, I have to say Superman did a pretty good job of tightening them together at the factory! now it's time to relax and grab a cold one
11-26-2009, 05:59 PM #3
Question: air check valve pipe
Yeah well ah I'm about ready to tackle that and a set of longtube headers sometime week from Saturday,
By the sounds of it It should be fun
Wish me Luck cause I'm going under !
Bon
11-26-2009, 06:07 PM #4
I changed both check valves last year -- could not get either one to come off while still on the car. Removed the tubes from the manifolds so I could work on them off the car and still could not get them to budge. Ended up using a propane torch and wicked candle wax into the threads. That did the trick.
11-27-2009, 05:43 AM #5Member
- Dec 2006
- Warren, Ohio
Navy Blue Metallic- 2002 Camaro SS
I too had to repalce both at different times. Due to SES codes. My friend at a local auto garage did it. Now after hearing about the problems I'm glad I did that.
08-08-2010, 04:41 PM #6
08-08-2010, 05:09 PM #7
Here you go: http://www.ls1.com/forums/showthread.php?t=130641
08-09-2010, 12:15 AM #8
08-09-2010, 01:36 AM #9
08-09-2010, 02:48 AM #10
No problem, glad I could assist. I also had a heck of a time changing the valves out on our car after we first bought it. I ended up removing the tubes from the manifolds and heating the unions with a propane torch. I then hit the threads with some candle wax while they were still hot and used a pipe wrench.
Question: Fuel check valve
By ponyslayer in forum General HelpReplies: 6Last Post: 08-20-2015, 11:38 AM -
Air Check Valve help
By Ramairgod84 in forum General HelpReplies: 8Last Post: 09-19-2012, 02:10 PM -
air check valve
By mthorn in forum Stereo and ElectronicsReplies: 8Last Post: 10-23-2008, 12:18 PM -
AIR Check Valve Won't Come loose
By jimmy77611 in forum General HelpReplies: 3Last Post: 06-08-2007, 07:36 AM -
AIR Check Valve
By KM02SS in forum General HelpReplies: 6Last Post: 10-09-2006, 01:24 PM
