Thread: AIR Check Valve Won't Come loose
06-08-2007, 06:49 AM #1
Is there a trick to unscrewing the AIR check valve off of the tube? Mine doesn't want to budge. I sprayed liquid wrench and let it soak, still nothing. If I pull any harder on the wrenches, it seems like I'll mess up the hex nuts!
06-08-2007, 06:51 AM #2
Did you heat the car up pretty good!
06-08-2007, 06:58 AM #3
It was pretty warm from driving, but I didn't try heating the threads with a torch. I have one of those plumbing type propane torches, maybe I'll try that.
06-08-2007, 07:36 AM #4Impounded
- Feb 2007
- Pa
Red- 99 TA
pull the tube off the car and put in in a vise then remove it.They get stuck on hard enough that you may break something off if you don't do in in a vise.Put high temp antisieze on the new one so the next time they will remove easily.
Question: Fuel check valve
By ponyslayer in forum General HelpReplies: 6Last Post: 08-20-2015, 11:38 AM -
Air Check Valve help
By Ramairgod84 in forum General HelpReplies: 8Last Post: 09-19-2012, 02:10 PM -
air check valve
By mthorn in forum Stereo and ElectronicsReplies: 8Last Post: 10-23-2008, 12:18 PM -
AIR Check Valve
By KM02SS in forum General HelpReplies: 6Last Post: 10-09-2006, 01:24 PM -
Air Check Valve and Hose
By Roxboro Burnout in forum General HelpReplies: 5Last Post: 04-16-2006, 04:02 PM
