Thread: AIR Check Valve
10-09-2006, 08:28 AM #1FAS02SS
- Apr 2006
- Greenwood Indiana
Pewter- 2002 Camaro SS
AIR Check Valve
My car threw a SES code P1416 AIR bank 2 and I was going to replace the passenger side check but I can't get it off. Has anybody else experienced this? I'm afraid I will damage the tube the check valve is threaded onto if I'm not careful, any suggestions??
10-09-2006, 08:37 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
Use two wrenches - one to hold the metal air tube steady, and one to unscrew the valve. If it's really tight unhook the air hose/clamp, remove the metal air tube from the car (2 bolts) and do it off the car. Don't overtighten the bolts on the manifold when you resinstall it, only something like 10lbft.
10-09-2006, 10:20 AM #3FAS02SS
- Apr 2006
- Greenwood Indiana
I tried the 2 wrench method, wouldn't budge. Haven't tried removing air tube from exhaust manifold yet, will bolts be seized in exhaust manifold?
10-09-2006, 10:29 AM #4Senior Member
- Jul 2005
- Jacksonville, FL
Shouldn't be, I've had mine off a couple times doing plugs. There is a gasket under the metal air tube, PN 12553617 (cheap) if it doesn't reseal properly - but mine are still original. Buddy of mine w/a '99 had to take his off and put it in a vice to get it off. I'll look up the exact torque specs on the bolts for you...
10-09-2006, 10:43 AM #5Senior Member
- Jul 2005
- Jacksonville, FL
15 lb ft - but didn't torque mine...just don't want you to snap the head off and have to drill it out. (Helms says to use a "NEW" gasket, but like stated earlier I didn't have to).
10-09-2006, 11:11 AM #6
you must pull the tube off the manifold,then put it in a vise and its dam hard to get off.
10-09-2006, 01:24 PM #7
Gotta use some muscle...you could also try some penetrating spray like wd-40. If you're a smaller guy like me you can get in the engine bay and use your weight to help, that's what I did
Question: Fuel check valve
By ponyslayer in forum General HelpReplies: 6Last Post: 08-20-2015, 11:38 AM -
Air Check Valve help
By Ramairgod84 in forum General HelpReplies: 8Last Post: 09-19-2012, 02:10 PM -
Question: air check valve pipe
By RickZ2899 in forum General HelpReplies: 9Last Post: 08-09-2010, 02:48 AM -
air check valve
By mthorn in forum Stereo and ElectronicsReplies: 8Last Post: 10-23-2008, 12:18 PM -
Air Check Valve and Hose
By Roxboro Burnout in forum General HelpReplies: 5Last Post: 04-16-2006, 04:02 PM
