Thread: air check valve
10-22-2008, 05:21 AM #1Junior Member
- Jun 2008
- missouri
black- 1999 camaro convertible
air check valve
does anyone have a picture or can describe where the air check valve is on a 99' Z28? My chiltons manual sucks. Thanks.
10-22-2008, 05:47 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
P1416 code right? It's the black disc shaped valve in between the metal air pipe coming off the front of the manifold, then connects to the air hose with a clamp. It's right above the cyl #4 coil.
10-22-2008, 06:08 AM #3Junior Member
- Jun 2008
- missouri
thats the exact code. thanks.
10-22-2008, 11:33 AM #4Junior Member
- Jun 2008
- missouri
http://www.ls1.com/forums/showthread...ir+check+valve
i found another thread that has a picture. is what is circled in the picture where it is?
10-22-2008, 11:56 AM #5Senior Member
- Jul 2005
- Jacksonville, FL
Yep, that's it.
10-23-2008, 10:16 AM #6Junior Member
- Jun 2008
- missouri
i am having a hard time getting the valve off. are there any tricks? the hose is on there very tight. i think what i am going to have to do is take the metal tube off if the engine to the valve off of that side. when i tried to unscrew it, it started to bend the tube. thanks.
10-23-2008, 11:11 AM #7Senior Member
- Jul 2005
- Jacksonville, FL
Unclamp the hose and remove it from the valve. Use two wrenches to unscrew the valve from the metal pipe, one to hold it steady and the other to unscrew it. If you still can't get it unbolt the two bolts and remove it from the car and do it on a bench or in a vice. There's a gasket under the two bolts (GM PN 12553617, cheap from the dealer) in case it tears, but probably will be fine. If you remove the pipe don't overtorque the two bolts when you reinstall it, remember it being pretty low - I'll look it up and post.
10-23-2008, 11:24 AM #8Senior Member
- Jul 2005
- Jacksonville, FL
My '01 helms says 15 lb ft for the secondary air pipe bolts.
10-23-2008, 12:18 PM #9Junior Member
- Jun 2008
- missouri
thanks once again.
Question: Fuel check valve
By ponyslayer in forum General HelpReplies: 6Last Post: 08-20-2015, 11:38 AM -
Air Check Valve help
By Ramairgod84 in forum General HelpReplies: 8Last Post: 09-19-2012, 02:10 PM -
Question: air check valve pipe
By RickZ2899 in forum General HelpReplies: 9Last Post: 08-09-2010, 02:48 AM -
AIR Check Valve
By KM02SS in forum General HelpReplies: 6Last Post: 10-09-2006, 01:24 PM -
Air Check Valve and Hose
By Roxboro Burnout in forum General HelpReplies: 5Last Post: 04-16-2006, 04:02 PM
