Thread: hard reverse
    memphis tn
    green
    1997 camaro ss
    Question hard reverse
    I have a 97 ss 6spd.the trouble im having is it doesnt want to go in gear sometimes,like if im pulling up to a red light and i just put it in neutral its hard to get back in first,but if i downshift to second then first while approaching the light it does just fine.also sometimes it doesnt want to go in reverse but if i put it in reverse or 6th before i start the car it will go in just fine.i dont know if its the clutch or what.a friend of mine said it may be shift forks,but im not sure.
    Oct 2001
    Colorado
    95 Z28
    It's probably either the clutch or the slave cylinder, assuming there are no driveability problems with the transmission itself when it is in any gears.
    memphis tn
    green
    1997 camaro ss
    Driveability is fine once i get it into gear,but sometimes reverse is really hard to get in,unless the car is not running and i put in 6th then it seems to go in fine.
    LT1KING GOODZ/BADZ's Avatar
    Fontana, Ca.
    Black/Black
    96 Vert Z28-RIP/94 TT Z28
    Probably the synchros for that particular gear, if the slave or clutch were bad you'd have trouble gettin it into any gear.
    Aug 2000
    Indy
    I'd guess synchros
    SoCal
    96 TransAm
    That was the signs of my synchros going out when they did. It started out really small and got progressively worse throughout the different gears.
    memphis tn
    green
    1997 camaro ss
    are the synchros hard to get to?do u have to drop the tranny?i'm not mr. goodwrench or nothing but i'm decent with the wrenches.
    Oct 2001
    Colorado
    95 Z28
    You have to have the tranny out of the car to be taking synchros out of it. That is an internal part of the tranny. The whole thing has to come apart.
  1. Question: rear shocks bottoming out on hard reverse?
    By JayTA98 in forum General Help
    Last Post: 06-24-2011, 12:07 PM
  2. Help: Hard to shift after using reverse!
    By Ryaleon in forum Manual Transmission
    Last Post: 09-27-2010, 03:32 PM
  3. hard shifting and reverse pops out
    By evil_goat in forum GTO
    Last Post: 07-14-2009, 10:00 AM
  4. Help: will not come out of reverse
    By Mr.Gomez in forum Manual Transmission
    Last Post: 09-30-2008, 07:56 AM
  5. Help: No Reverse!
    By 98_Z28_ls1 in forum Automatic Transmission
    Last Post: 04-06-2008, 06:43 AM
