Thread: No Reverse!
04-05-2008, 08:42 AM #1
No Reverse!
Yesterday I pulled into my driveway and everything was fine. later on that day I go to back out and put it in reverse and nothing happens...so I'm sitting in reverse and not moving so i give it some gas. the RPM's go up to 2000 exactly and it won't go any higher...Bottom line is: park is park, reverse is park, neutral is DRIVE, 1 2 d & D are forward gears, and a rev limiter of 2000 RPM's. Has this happened to anybody else? if so how did u fix it. i dont know a lot about cars so ANY help will be Greatly appreciated.
04-05-2008, 09:08 AM #2
sounds like you should probably (carefully) take it to your mechanic/dealership/whatever... i've never heard of anything like that. maybe someone else has...
04-05-2008, 09:26 AM #3
pm Performabuilt with your problem and/or post your question in the automatic section
04-05-2008, 11:11 AM #4
You likley have a seized forward clutch . You will need to rebuild or replace the trans
, Give me a call if I can be of any help
04-06-2008, 06:43 AM #5member since may 2000
- Dec 2002
- n/w chicago
rebuild time
a few bolt ons, 379 rwhp
11.96 @113.25
Won't Go Into Reverse
By 69er in forum Manual TransmissionReplies: 11Last Post: 05-26-2012, 11:38 AM -
Help: no 1st or reverse
By Mars in forum Manual TransmissionReplies: 7Last Post: 02-21-2009, 12:10 PM -
Help: will not come out of reverse
By Mr.Gomez in forum Manual TransmissionReplies: 8Last Post: 09-30-2008, 07:56 AM -
No reverse
By ssweet99ss in forum Manual TransmissionReplies: 0Last Post: 08-30-2008, 02:21 PM
