    Feb 2012
    Alamogordo, New Mexico
    69 Camaro Pro-Touring
    Won't Go Into Reverse
    I did a search and didn't see anything similar to my problem.
    I have a 06 GTO T-56 sitting on the bench with a new B&M shifter installed. I can go through all the gears but the shifter will not enter the fourth gate over to allow me to push the shifter up into reverse.
    Anybody have some ideas that I can look for?
    Thanks!
    Larry
    Feb 2012
    Update:
    Thought of something...
    When the reverse lockout system is activated, does it keep the shifter from going into the gate or does it allow it to go into the gate, but not up into reverse? My thinking is that maybe the solenoid or other part of the system is jammed.
    Larry
    Feb 2012
    Update 2:
    I removed the reverse lockout solenoid and discovered that is what is causing the problem; the solenoid rod is spring-loaded in the out position. Is this normal? That tells me I wouldn't be able to put it in reverse if the car is turned off. That doesn't seem right!
    In a typical LS conversion into an F-Body is the reverse lockout programmed for use? Maybe I can just plug the hole if it's not.
    Arizona
    Sounds like yours is working normal. The reverse lockout will not allow reverse until the key is on and power is signaled to the transmission.
    So you won't be able to find reverse while it's sitting on the bench.
    Yes this function is also on the Fbodies. Reverse is syncronized so you can put in reverse while rolling forward, but in the tune that is limited to about 3 mph while rolling forward or backward. Above 3 mph and the lockout engages. You can adjust that in the tune, but I see no reason why.
    Since reverse is in a precarious position, I'd recommend keeping the lockout feature. As you are going for 5th it's very easy to get hung up in the reverse gate (or even engage it) if the lockout feature isn't there. Besides, there is no reason not to have it.
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Agree with FBJ. It's there for a good reason, and can keep severe damage from occuring.
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Is it even possible (mechanically) to engage reverse if the car already has enough forward speed to be in 5th gear? I always thought that the motion of the transmission would just cause you to "grind" if you tried to hit reverse while in forward motion? I have never tried, and never will, so I don't know...
    Arizona
    Quote Originally Posted by Naaman View Post
    It would be possible if you disabled the reverse lockout like the original poster mentioned.
    Otherwise no, it is set in the tune to engage above 3 or 4 mph. Reverse is syncronized in these transmissions, so it will never grind in reverse while rolling forward (unless the syncro is shot).
    May 2012
    Chattanooga,Tn
    1999 Camaro
    Hi I have a 1999 v6 with a manual transmission and i went to reverse and it didnt move then it made a loud noise and shut down. The car was driving fine for about 3 days and today i for got my reverse didnt work and went to reverse and it got stuck in the reverse gear. I had to get in the back seat to push it out of gear. The car was driving fine till i switched to 5th gear. When i put the car in 5th gear it was like i was not in gear. DO ANYONE KNOW WHATS WRONG AND HOW MUCH THIS WILL COST TO FIX. THANKS
    99 WS.6 - Modified
    Hard to say without a teardown, but I'd guess something fairly major if it got stuck in gear and stalled the engine. Cost will depend on what you are able to do yourself. If you can remove the tranny, you can save a decent amount, and take it to a shop. I'd still guess near $1000 give or take.
    May 2012
    Chattanooga,Tn
    1999 Camaro
    I can replace the transmission, but this is my first manual and not sure about if i have to change the gear box or not. ( or is that part of the whole transmission?)
    99 WS.6 - Modified
    You're better off removing the entire unit.
    May 2012
    Chattanooga,Tn
    1999 Camaro
    ok thanks
  1. Help: no 1st or reverse
    By Mars in forum Manual Transmission
    Last Post: 02-21-2009, 12:10 PM
  2. Help: will not come out of reverse
    By Mr.Gomez in forum Manual Transmission
    Last Post: 09-30-2008, 07:56 AM
  3. No reverse
    By ssweet99ss in forum Manual Transmission
    Last Post: 08-30-2008, 02:21 PM
  4. Help: No Reverse!
    By 98_Z28_ls1 in forum Automatic Transmission
    Last Post: 04-06-2008, 06:43 AM
