    Aug 2010
    2002 Pontiac Firebird T/A
    Hard to shift after using reverse!
    So last saturday i'm driving around and everything was fine. i go into a store and when i come back out i put the car in reverse and everythings still fine. Then when i go to shift it i have to muscle it into first gear, but once its in first gear normal shifting resumes. The car is only difficult to shift as im coming from reverse. any ideas?? its an 02 Trans Am m-6.
    Member natews6's Avatar
    Apr 2010
    Missouri
    1999 WS6(sold) 2003 Cobra
    When I had this problem I initially thought it was just a pilot bearing, I ended up needing a whole new clutch assembly because it was grinding metal to metal with my flywheel. I really didn't think it was the clutch because it shifted PERFECT, the worn out clutch actually felt better than the new Hays clutch that I put in... Hope this helps
    I was going to ask how many miles on current clutch but the post above me hinted at that.
    Aug 2010
    so you think its the clutch then?
    Need more info, how many miles for the car? Do you know when the clutch was last service? I've heard of stock clutches going out at 40k and then you have some like mine that lasted till 115k. It all depends on the owners and how they drive them. I got lucky, the previous 2 owners treat her like a newborn baby. I bought mine knowing I was going to upgrade and did so. It could also be the syncros. Not to sure about that. I know if shifting from 2nd to 3rd and it grinds all the time that is a sure sign.
    I hope I'm not leading you down the wrong path.
    How far is the travel of your clutch pedal when you shift? meaning is it close to the top or the bottom of the floor? Your slave might be going and that can cause engagement issues.
    Aug 2010
    ummm ok car has 105,000 miles. clutch was replace at 86,000 i think so farely new. I have no grinding issues whatsoever. Shifter just gets hard to move after reversing. then after I do get it back in a forward gear and drive a very short ways its like nothing ever happened. its strange to me that it only happens right after reversing.
    check your fluid levels? Could be low? Sounds like a binding issue. Try to PM Cutlass (Mod and mechanic) he and Orion (mod) are the guys I ask questions directly when I have a hard time getting an answer.
    Now be honest on this one here - Do you do burn outs, race, or hard launches with it? Like i said in an earlier post. A OEM clutch will last depending on how the driver treats it. Hard launches, burn outs, and racing kills the life of the clutch.
    Aug 2010
    yeah i thought it was low fluid at first and i was hoping it was that, but i had it checked at avis and its fine. im gonna take it in on wednesday i think. btw binding is like the perfect word to describe how it feels.
    Apr 2010
    Missouri
    something is dragging the input shaft... best way to find out is to drop the trans and check it out.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Quote Originally Posted by natews6 View Post
    Thats my thoughts as well. either pilot bearing or clutch hydraulics issue.
    Aug 2010
    It was the reverse lockout solenoid, what should replacing this cost generally?
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    A. That sounds very strange....
    B. It's an easy replacement - I would think one hour of labor or less + the solenoid.
  1. Question: rear shocks bottoming out on hard reverse?
    By JayTA98 in forum General Help
    Last Post: 06-24-2011, 12:07 PM
  2. Can't shift into Reverse
    By JwMonE99 in forum Manual Transmission
    Last Post: 08-18-2009, 08:15 AM
  3. hard shifting and reverse pops out
    By evil_goat in forum GTO
    Last Post: 07-14-2009, 10:00 AM
  4. difficult to shift into reverse
    By grouch0jr in forum Manual Transmission
    Last Post: 09-23-2008, 09:06 AM
  5. hard reverse
    By 97SS in forum LT1
    Last Post: 01-18-2006, 02:33 AM
