Thread: change tranny fluid or flush?
09-26-2008, 07:43 PM #1
Should I just change my fluid or get it flushed? I remember reading somewhere that flushes can be bad for the transmission?
LS6 Engine swap, Custom Predator Tune, Lid, SLP Cold Air, Ram Air H.O. Hood, Hooker Long Tubes, !Cats, 3" True Duals w/Dynomax Bullets, Performabuilt stage 2 w/3600 stall, B&M Trans. Cooler, Moser 12 Bolt w/ 3.73's
Pics of my car
http://community.webshots.com/user/demonspeed_ta
09-27-2008, 01:32 AM #2
I've always just dropped the pan and changed the filter and add new fluid to top it off. I do it fairly regularly so the fluid stays fresh even though dropping the pan only gets about a third out.
09-27-2008, 02:28 PM #3Junior Member
- Apr 2007
- denton,Texas
Change it...most flushs don't include changing the filter... jus to mention 1 problem I have with these flushes. Hope this helps Dave
09-27-2008, 02:46 PM #4
i reckomend both, regular changes and a flush from time to time. ive heard that if you do a flush on a higher mileage tranny that has not had a flush it can push junk into lines and ports and can cause problems but ive flushed all the trannies ive ever had and never had this issue
09-27-2008, 03:17 PM #5
09-27-2008, 05:45 PM #6Junior Member
- Apr 2007
- denton,Texas
yeah
It says so in your owners manual too.....Flush that is.... Aw never mind I've said enough...lol....Dave
09-27-2008, 06:01 PM #7
cool thanks for the good info guys. guess im gonna get it flushed and new filter and hope for the best.
10-10-2008, 08:13 PM #8
If you've maintained your tranny go ahead and flush it, if not a flush may break loose all the gunk in you tranny and cause internal leaks. The gunk actually becomes part of the seals and a flush can break that up.
10-10-2008, 09:03 PM #9- STOCK ish -
- Apr 2008
- Fairhope, Alabama
Black- 2002 Camaro SS SLP
I just got mine flushed with new filters, i can tell the difference, it shifts better
2002 Camaro SS A4 - SLP# 2951 l MS4 l LT's w/ORY l F.A.S.T 78 & TB l Borla l Cutout l CME l TCI 3500 l 3.23's l !emissions l !sway
Hydraulic Clutch Fluid flush...
By OnEbAdReDSS in forum Manual TransmissionReplies: 14Last Post: 05-11-2014, 06:31 AM -
Tranny filter and fluid change
By thearborbarber in forum Automatic TransmissionReplies: 0Last Post: 05-12-2008, 06:26 PM -
manual tranny fluid change
By MISFIT in forum Manual TransmissionReplies: 10Last Post: 10-08-2006, 06:35 PM -
transmission fluid flush......
By redz284u in forum Automatic TransmissionReplies: 1Last Post: 02-19-2006, 04:56 AM -
Coolant Flush*Fluid?
By 01JameSS in forum General HelpReplies: 13Last Post: 10-04-2005, 05:12 AM
