Results 1 to 14 of 14
Thread: Coolant Flush*Fluid?
09-28-2005, 08:37 PM #1Junior Member
- Los AngeleSS
Light Pewter Metalic- 01 Camaro SS
What is a good fluid to purchase? And what is the name of that fluid that enhances the cooling process? Ohh yeah and how much coolant is required for a coolant flush????thanks a load guys….
09-28-2005, 09:06 PM #2
The flushing is done with water from your garden hose, you only need enough coolant to fill it back up when you're done (4 gallons at the absolute most)
09-29-2005, 04:46 AM #3Member
- Yardley, PA
Black- 2001 Camaro SS
use a good extended fluid like the red/orange Dexcool, or the yellow stuff, stay away from the green stuff. Also throw in a bottle of Wetter water or purple ice, they will help lower a few degrees
09-29-2005, 05:13 PM #4Junior Member
- Los AngeleSS
thanks for the name of the purple ice i forgot the name of it...so about 4 gallons should do it, aren't you suppose to put some water in there, to go with the coolant????
Originally Posted by mcamp001
09-29-2005, 05:15 PM #5Grand Imperial Wizard
- Retired Outlaw Sum Bitch
50-50 mix of distilled water and your anti freeze......you can also buy it now already mixed.....
Originally Posted by 01JameSS
09-30-2005, 06:32 PM #6
Just under 3 gallons is the total capacity of the system-but you won't get it all to drain.Don't worry about it that's normal.Buy 2 gallons of antifreeze and put your Purple Ice in first.Premix your antifreeze w/distilled water and save what's left for topping off later.Look at it after it cools back off and make sure your level is still OK-look again the next day you run it just to be safe.
09-30-2005, 08:52 PM #7Junior Member
- Los AngeleSS
Originally Posted by 02z28ls1
Good stuff.....
09-30-2005, 11:09 PM #8
is purple ice safe to use with dex? Cause if it has silicates it pretty much defeats the purpose of dex.
10-01-2005, 03:06 AM #9Grand Imperial Wizard
It is 100% perfectly safe/fine with Dex-Cool......and this stuff does work....
Originally Posted by SeVeReDiStOrTiOn
"Back in the day" we would put some dishwashing liquid in to accomplish the same thing
I think Purple Ice works a little better....
10-01-2005, 10:04 AM #10haha...dishwashing fluid, how much did you put in? What exactly does purple ice do anyway...does it raise the boiling point of the coolant?
Originally Posted by Sarge
10-01-2005, 04:06 PM #11Grand Imperial Wizard
No it (like dishwashing soap.....Dawn is good) makes the hot points that boil off water less "sticky" so know the water can run over these hot points versus around them...thus cooling.....I was the biggest skeptic...but the guys just swear by the stuff...and hell they have been using it for awhile...so I did my own little test...and kiss my butt...it really did drop the temps....
10-03-2005, 10:21 PM #12We'll be back...
- THE SWAMP
Yep, because it reduces the surface tension of the water.
10-04-2005, 12:23 AM #13BlackHawk T/AGuest
Do Purple Ice and Watter Wetter do the same thing or is one better than the other?
10-04-2005, 05:12 AM #14Member
- Yardley, PA
same stuff, different label, different color
Coolant flush
By Z28_Driver in forum General HelpReplies: 7Last Post: 03-21-2010, 04:50 AM -
Coolant Flush
By BlackTAWS6 in forum General HelpReplies: 15Last Post: 10-09-2008, 07:21 AM -
Coolant Flush
By Sarge in forum GTOReplies: 6Last Post: 04-13-2008, 08:07 AM -
Coolant Flush
By samson_420 in forum General HelpReplies: 13Last Post: 10-28-2007, 08:21 AM -
transmission fluid flush......
By redz284u in forum Automatic TransmissionReplies: 1Last Post: 02-19-2006, 04:56 AM
