Results 1 to 16 of 16
Thread: Coolant Flush
01-06-2006, 05:11 PM #1
Coolant Flush
Going to do it this weekend, but just was wondering what is the best way to do it? Coolant Flush that is.
Thanks
Billy
01-06-2006, 05:24 PM #2Alcohol Injected
- Nov 2005
- Knoxville,Tn
Black- 1999 Pontiac Firebird
I recommend Peak Global Antifreeze, beware the DexCool
pop the drain plug and run it while putting a hose to the filler neck.... I would go ahead and install a cooler 160 Thermostat while your at it, if you havent already. Or you can drain radiator and fill with water run it to operating temp and then drain and refill, repeat. -TimLast edited by PaganEgyptian; 01-06-2006 at 05:32 PM.
01-06-2006, 07:20 PM #3
Prestone makes a flush additive also...supposed to clean the system out pretty good. You follow the normal fluch process and the cleaner gets more crap out.
01-07-2006, 04:13 AM #4I keel you!
- Titus,AL
Black as Wesley Snipes- 09 Mazda 3, 12 Z1000
incase the wondering the drainage petcock is on the underside of the RAD, I think the passenger side. just feel around the bottom and you'll come across it
07-24-2006, 06:16 PM #5Junior Member
- Jul 2006
- Orlando, FL
White- 1999 Camaro SS
Need some help
Does anybody have a pic of where the drainage petcock valve is?
I plan on using Dex (it has worked for me), then filling the rest with regular distilled water from the grocery, then using Water Wetter. I already have the 160 thermo.
Just to be sure.
1. Unhook lower radiator hose
2. Unplug drainage petcock
3. Get a hose and run it through the system
4. Unhook upper radiator hose
5. Rehook everything and refill.
Thanks.
07-24-2006, 07:45 PM #6
07-30-2006, 04:24 AM #7
I just used the Prestone Rad flush on my girls Neon. Then I tore the engine apart for a head gasket fix. The flush worked great, cleaned it up like new! I plan to use it on my TA soon too.
I'm changing away from Dex cool also. A lot of talk on that stuff clumping up in the radiators and collecting as a slimey grey matter. I would think if you flush and change fluid regularly, it would be no problem. I'm going to the Red Line and water mix. But my TA is a nice weather, track car... no winters.
07-30-2006, 06:25 AM #8
First i would drain the ra. from the plug too prevent a mess.
Then i would put a hose in the rad and start the car and let it circulate "op. temps" with the plug open and then when it starts flowing clear water out the bottom i would shut it off let it finish draining then replace with new fluid.
Heres a pic its on the pass. front, right below the rad.
J
09-21-2008, 10:40 AM #9Junior Member
- Sep 2008
- Tampa,FL
White- 1994 Z28
how do you get the air out of the system?
09-21-2008, 01:23 PM #10
09-21-2008, 02:27 PM #11Member
- Nov 2007
- SATX
Pewter- 2000 Trans Am
or have the car running with the Rad cap off and wait till all the air bubbles are gone.
09-21-2008, 02:43 PM #12
09-22-2008, 12:58 PM #13
I think you do this when the car is off.
I tryed flushing mine, and kept waiting for the water to come out the hose of the tb bc it was disconnected with the rad open and filling it with buckets.
...after about 45 min of nonesence and running in circles bc it would still start to over heat and no water came out....
I said f*it and turned it off top the rad and finally the water came out of the hose like everyone talked about...
my internet was down at the time so i thought reading it so many times it was a piece of cake
09-22-2008, 05:40 PM #14
10-09-2008, 04:51 AM #15
what do you guys do with your old rad. fluid when you are done?
10-09-2008, 07:21 AM #16MOTOR CITY MARO'
- Nov 2005
- LIVONIA,MICHIGAN
PEWTER- 2000 CAMARO SS #3821
Careful, if you run a hose until the radiator drains out clear and stop. Your engine is now filled with hose water and no antifreeze, so to get the proper 50/50 is tricky. If you buy pre-mixed 50/50 then you really would be dilluted.
I like just draining the radiator and then refilling with pre-mix and that way maybe 50% is changed but the "hard water" is not in the system.
Coolant flush
By Z28_Driver in forum General HelpReplies: 7Last Post: 03-21-2010, 04:50 AM -
Stripped bolt for coolant flush ????????
By brian r in forum General HelpReplies: 9Last Post: 06-22-2009, 07:40 AM -
Coolant Flush
By Sarge in forum GTOReplies: 6Last Post: 04-13-2008, 08:07 AM -
Coolant Flush
By samson_420 in forum General HelpReplies: 13Last Post: 10-28-2007, 08:21 AM -
Coolant Flush*Fluid?
By 01JameSS in forum General HelpReplies: 13Last Post: 10-04-2005, 05:12 AM
