Results 1 to 2 of 2
    Member redz284u's Avatar
    Littlerock, CA
    1998 SS
    transmission fluid flush......
    i want to flush the tranny oil out like they do at the jiffy lube....can i do this by disconecting the line that takes the fluid to my tranny oil cooler, and fill as it drains??????any other methods of doing this would be appreciated....
    98SS A4, TSP CLR LID, LS6 INTAKE, BMR SFC/STB/ LWR CNTRL & TRQ ARMS, KYB ADJ., HOTCHKINS SWAY BARS, MSD WIRES, JETHOT LT/ORY, MAGNAFLO CATBACK, EIBACH PROKIT, 19" TSW WHEELS, PERMA COOL TRANY COOLER.
    257.8 hp (MUSTANG-DYNO) b4 ANY MODS.
    13.6 1/4 mile
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    you can. that's basically what a flush machine does. this is about a ten quart job. so, make sure you have at least ten quarts in a bucket with the line submerged in the bucket to suck it all in at the same time you are dumping the old fluid out.
  1. Hydraulic Clutch Fluid flush...
    By OnEbAdReDSS in forum Manual Transmission
    Last Post: 05-11-2014, 06:31 AM
  2. Transmission Flush
    By pajeff02 in forum Automatic Transmission
    Last Post: 05-12-2011, 08:06 AM
  3. change tranny fluid or flush?
    By DemonSpeed in forum Automatic Transmission
    Last Post: 10-10-2008, 09:03 PM
  4. transmission flush, help or hinder?
    By Wheels in forum Automatic Transmission
    Last Post: 10-24-2007, 05:23 PM
  5. Coolant Flush*Fluid?
    By 01JameSS in forum General Help
    Last Post: 10-04-2005, 05:12 AM
