Results 1 to 3 of 3
10-23-2007, 01:38 AM #1Junior Member
- Sep 2007
- North America
Navy Blue Metallic- 1999 Trans-Am
transmission flush, help or hinder?
A couple of times now my 99 TA has bounced of the rev limiter insead of shifting 2-3, not everytime, but it happens. After a few searches I've found a bit of info and it seems it's not uncommon and can be an early sign of impending tranny trouble.
I'm considering a transmission flush, and rear gear oil change while I'm at it, but I've noticed some controvercy about if it's a good idea or not. Opinions on if a tranny flush is a good idea?
If/when I do go ahead with it, what fluids (availiable at your local jiffy-lube) would you recommend, because that's where it's going to be done. I'm not capable of ding the work myself and I'm no more trusting of the stealership than I am the drive through oilchange joint and at least the drive-through has conveinience on it's side and I can see it being done.
10-23-2007, 04:03 AM #2
IMO, go to the dealership for the transmission service. Most GM dealerships have a special machine that uses a pressure cleaner. It sucks out all the old fluid, sends a high pressure cleaner through the trans, torque converter included and then puts new fluid in. Usually charge around $150 and recommend every 60k, so just a good investment for the $$. Just my opinion.
2018 Tahoe - Silver - OEM
10-24-2007, 05:23 PM #3
if it's bouncing off the limiter on the 2-3 shift now, a flush will not help at all. most likely hurt. transmission fluid has detergents in it to clean. if the clutches are worn, it'll clean whatever you have left off. your 3/4 clutch pack is getting worn too much.
you can crutch it, by raising the line pressure, to apply more pressure. but, time to save up for a rebuild.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
Transmission Flush
By pajeff02 in forum Automatic TransmissionReplies: 23Last Post: 05-12-2011, 08:06 AM -
Flush 411
By Sarge in forum Automatic TransmissionReplies: 18Last Post: 12-27-2010, 02:25 PM -
Hinder's Up All Night Video ;)
By RiceEater in forum Almost Anything GoesReplies: 7Last Post: 07-03-2009, 11:28 AM -
I'm sorry but Hinder sucks
By 310stanger in forum Almost Anything GoesReplies: 38Last Post: 05-31-2007, 03:38 AM -
transmission fluid flush......
By redz284u in forum Automatic TransmissionReplies: 1Last Post: 02-19-2006, 04:56 AM
