Results 1 to 11 of 11
Thread: manual tranny fluid change
08-24-2006, 08:17 AM #1
not hard to do right? what are the steps? or links to a guide?
08-25-2006, 04:41 AM #2
08-25-2006, 05:16 AM #3Detailing + Design
- Pittsburgh, PA
i'd help, as i did this about 5 months ago, but i forget where to pour the fluid back in....sorry man.
08-29-2006, 01:33 AM #4
i just did mine a month ago. pretty straight forward, the drain is located at the tail shaft housing( passenger side). Remove this plug to drain out the old fluid( becareful it comes out pretty fast). The fill plug is on the drivers side of the tranny right in the middle. It takes 4 quarts of fluid to fill back up (according to the owners manual).
09-13-2006, 09:23 AM #5Junior Member
- Jun 2006
- Spokane WA
Black; Silver- 99 Z28; 04 Silverado
What fluid do you guys use. I think I will use Amsoil ATF.
09-13-2006, 11:46 AM #6
09-15-2006, 08:17 AM #7
atf in a manual, i was going to do my trany fluid too but i was going to use synchro mesh......what do you guys think?
09-15-2006, 05:14 PM #8
I use royal purple syncrmesh. good stuff
09-16-2006, 03:34 PM #9
It says "Use Only Dexron III ATF" imprinted right on the side of the transmission casing. If gear oil/synchromesh was an option, they would have put that on there.
Just use Dexron ATF, thats what the trans is designed for. Why use the wrong fluid?? Doesn't make sense.
09-18-2006, 07:03 AM #10
Thanks, I have had the car only 3 weeks and havent been underneath it yet...
10-08-2006, 06:35 PM #11
I've used Redline D4 for about 4 years now. Get some thread sealer with teflon from the auto parts store for the drain and fill plugs.
Manual Transmission Fluid
By V8MUSCLE in forum Manual TransmissionReplies: 3Last Post: 01-27-2010, 07:36 PM -
change tranny fluid or flush?
By DemonSpeed in forum Automatic TransmissionReplies: 8Last Post: 10-10-2008, 09:03 PM -
Tranny filter and fluid change
By thearborbarber in forum Automatic TransmissionReplies: 0Last Post: 05-12-2008, 06:26 PM -
anyone know how to change the transmisson fluid on a manual 98 z28?
By camarossf650 in forum Manual TransmissionReplies: 46Last Post: 10-17-2007, 08:07 AM -
Tranny fluid?
By Black02LS1 in forum Manual TransmissionReplies: 5Last Post: 05-18-2007, 05:55 AM
