    Just a farmboy V8MUSCLE's Avatar
    Montpelier, VA
    2000 Pontiac Trans Am
    Manual Transmission Fluid
    whats the best...
    i know theres no "best", but what does everyone run in theres.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Use ATF. Thats factory spec.
    I run Mobil 1 Synthetic ATF, which is what most builders and performance shops reccommend.
    1998 Trans Am WS6 SGM
    Lid, Pro 5.0, WS6 Short Stick, LS7 Clutch, TB Bypass, Detroit TrueTrac, Poly Mounts, Bilstein Shocks, LS6 Intake, SFCs, CTS-V Brake Upgrade, STB, Nitto 555's. SS Longtube Headers and True Duals w/ H pipe and Magnaflows. Tuned by Harris Speed Works. 341.4WHP/346.1 lb/ft.
    Montpelier, VA
    i read in the owners manual that they do not recommend changing the fluid. why is this? do they want to sell me a new tranny down the road?
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by V8MUSCLE View Post
    I don't know why they put that in manuals. Guess they want people to think everything is "low maintenance".
    The bottom line is the fluid should be changed. If you run the car hard, I'd change it every 30K miles. If it never sees any hard use, you could probably do it every 50K miles.
    There is a drain and fill plug on the trans for a reason, definitely change that fluid
  1. Question: transmission fluid
    By Siciliano15 in forum Automatic Transmission
    Last Post: 03-09-2009, 07:37 PM
  2. transmission fluid
    By blackbird99 in forum Automatic Transmission
    Last Post: 01-16-2008, 06:49 AM
  3. anyone know how to change the transmisson fluid on a manual 98 z28?
    By camarossf650 in forum Manual Transmission
    Last Post: 10-17-2007, 08:07 AM
  4. A better transmission fluid?
    By Hot Rod SS in forum Manual Transmission
    Last Post: 01-03-2007, 10:19 PM
  5. manual tranny fluid change
    By MISFIT in forum Manual Transmission
    Last Post: 10-08-2006, 06:35 PM
