Results 1 to 20 of 47
08-16-2007, 01:07 PM #1
anyone know how to change the transmisson fluid on a manual 98 z28?
i have a 98 camaro z 228 6 speed,i was wonderin if anyone kus give me sum tips or know about any website that shows u how to change the fluid??
08-17-2007, 04:58 AM #2
you take the shifter out, thats where you put the fluid in....the drain plug is on the back of the tranny, you drain it, put the drain plug in, take the plug on the left side of the tranny out, fill the tranny w/AUTOMATiC III fluid from the top shifter hole till tranny fluid starts coming out the side plug hole......then put the side plug and shifter back in and ur ready to go!!
08-17-2007, 11:55 AM #3Senior Member
- Jun 2007
- corona ca
white, white and pewter- Rip99SSA4,74Z28M4,02SSM6
why cant you fill it from the top hole?? why do you have to take the shifter off thats stupid.
08-17-2007, 11:56 AM #4Senior Member
- Jun 2007
- corona ca
not stupid sorry, just doesnt make sense! but i just bought my 02ss yesterday with a m6 lol so... but i do work on car every day for a living and i would never think of taking all that shit off just to add fluid
08-17-2007, 12:39 PM #5Member
- Northern Virginia
BLACK- 2000 Camaro SS
I just used the 2 plugs, drain plug down low, fill plug higher up.
08-17-2007, 03:20 PM #6Senior Member
- Jun 2007
- corona ca
yeah thats all i do also, whats the theory behing adding fluid thru the shifter? tryin to lubricate that better or something?
all i wanna know is who is running synthetic in there m6?
and what kind?
08-18-2007, 08:58 AM #7Slow'er'Ass
- Thornton, CO
If you don't have a pump handy....fill at the shifter.
08-18-2007, 12:00 PM #8Member
- Jun 2007
- loyall ky
black, and black- 04 M6
fluid
i used b&m synethic fluid used a pump from the side hole
08-20-2007, 11:51 AM #9Awaiting Activation
- Jul 2007
- Midwest
black- 2002 Trans Am
I used a pump to fill thru the upper side hole. It is much more convenient than disassembling the console/shifter assembly. Fluid transfer pumps are cheap at Auto Zone.
08-20-2007, 12:27 PM #10Senior Member
- Jun 2007
- corona ca
yeah i just changed mine on saturday i used standard chevron dexron 3 and a 6 dollar pump. tranny shifts kinda shitty thou when cold i think i need to switch it to synthetic gear oil, might engage better when cold,
08-20-2007, 03:02 PM #11Slow'er'Ass
- Thornton, CO
I won't synthetics in my T56. Just a good brand new Dextron III. Or GM syncromesh.
08-20-2007, 04:53 PM #12
08-20-2007, 06:14 PM #13Slow'er'Ass
- Thornton, CO
I heard something about synthetics eating about an internal gasket (or something of the sort) on the earlier year T56's. 1998-2000.
That is all I need.
Thinking I might go with syncromesh myself when I change it this month.
08-21-2007, 05:35 PM #14
yea i just bought the synchromax royal purple oil,im about 2 do it ryte now,so ill c how it goes.im prolly gona go buy da pump because takin off my center console and all dat shyt is a pain in the ass
08-21-2007, 06:36 PM #15Slow'er'Ass
- Thornton, CO
Just got this from Six Speeds, Inc.
Looks like I will be picking up Mobil ATF tomorrow.: What transmission fluid do you recommend?
A: We use Mobil 1 ATF in all of our daily drivers. While Mobil 1 is what is desired some customers have trouble finding it in there locations. We also use GM Synchromesh. Royal Purple should not be used in a stock transmission as it has been known to cause premature blocker ring wear.
08-21-2007, 06:49 PM #16
ok i have a ? first i drain the tranny ryte? i will be putting the oil through the shifter,so wen i finish draining and all that,i start putting the oil in,nd den i just wait until the oil starts dripping and that means it full? and that its?
08-22-2007, 01:09 AM #17Awaiting Activation
- Jul 2007
- Midwest
Sounds like a plan. Put the drain plug back in, pull the fill plug. Start filling, and when the oil starts coming out of the fill hole, you're full. I did mine with the car level.
08-22-2007, 07:40 AM #18
08-22-2007, 07:51 AM #19
08-22-2007, 11:21 AM #20
Differential Fluid change
By LIGHTNINGMCQUEEN in forum DrivetrainReplies: 31Last Post: 04-04-2011, 12:11 AM -
Manual Transmission Fluid
By V8MUSCLE in forum Manual TransmissionReplies: 3Last Post: 01-27-2010, 07:36 PM -
Fluid change?
By Y2K_CAMARO in forum Manual TransmissionReplies: 15Last Post: 10-13-2008, 10:09 AM -
Fuel Rail and Injectors F/S Also 11 Bottles of Synthetic Manual Fluid
By dkishton1486 in forum Parts For Sale / TradeReplies: 0Last Post: 01-27-2007, 07:02 PM -
manual tranny fluid change
By MISFIT in forum Manual TransmissionReplies: 10Last Post: 10-08-2006, 06:35 PM
